ROTORA Big Brake Kits: CL, TL, TSX
#41
Originally Posted by pits200
Ha, I wish our car had some competition in the market. My buddy and I just put upgraded his car to 14 inch slotted rotors and 4 piston calipers on his 99GT mustang.
Total cost = $520 for the whole front setup.
I will toss another grand into the money I want to spend on brakes and go buy myself a Sony SXRD for the football season.
#43
Originally Posted by De La Rocha
I currenly haev 18" enkei PK6's on my whip...will the rotora bbk kits fit with this wheel?
#44
what is the normal offset needed on a wheel to clear the 13" rotors and 4-piston caliper? Thanks in advance, and Josh......Thanks for the fast shipping of the Rotora Rotors I ordered, YOU ARE A GREAT VENDOR!
#45
#46
I have a Rotora BBK on 2002 CL-S and I need new pads. . .do you have any recommendations. . .do I need to replace with Rotora race pads or are there others that are as good or better
#47
#49
Retired!!! ON TOP!!!
Originally Posted by Excelerate
Well it depends on the vehicle and the BBK. The 1 pc BBK is the 330X23MM whereas the 2 pc BBK is 330X30MM. To give you a reference, though, at least for the 1 pc BBK, the 99-03 TL and 01-03 CL require a 5MM spacer on the OEM wheels. I think you really only need 3 MM but they don't usually make spacers that small. The 04+ TL does not require a spacer for the 1 pc BBK with the OEM wheels.
When said that the BBK 1pc fits the 04+TL OEM wheels... did you mean the 17" or the 18"????
#50
Originally Posted by rodneyc77
Joshua,
#51
ive read up on the BBK kits, i have 99TL, i run type s rims in the winter, and 19x8 49offset rims in the summer, i know ill need a spacer for the type s rims, will they fit behind the 19s?
#52
#53
is there a large difference in brake force distribution between :
13" front BBK / 13" rear BBK
and
14" front BBK / 13" rear BBK
i'm projecting to buy fronts first, but i'm afraid to be disappointed about the balance if i get 13" front first, and after a while, putting rear 13" : that i should've taken 14" for fronts.
any input/review on this ?
thanks !
and
thanks !
#54
and
thanks !
and
thanks !
#55
can you buy cross-drilled (non-slotted) rotors only with the other stuff?
#62
Joshua,
Please send me the file for the fitment test.... 06 tl one piece 13" BBK.... 06 TL.... rodney_68@msn.com
Thanks you
Thanks you
#63
I have car ADD
Josh i think i am ready to get Rotora BBK's. Could you please send me the Excel file you were talking about so i can research..
I have 2006 TL (if you rememeber, u did my coils/rsb 2 months ago). In the summer i run 19 x 8.5" + 42MM. They are the same EXACT specs as the ron jon inspyres. Think it will clear?
i noticed you said that 14" is much
is 13" front * rear more then (overkill wise) the just 14" upfront.
I have to be real honest, the stock 5AT brakes are HORRIBLE. i need a resolution. especially if i become s/c
Thanks josh
Allon
Thanks josh
Allon
#64
Thanks josh
Allon
Thanks josh
Allon
Request the info you need so I can send you a chart/file on the BBK's. I would think the kits would clear fine. I know RJ designs his wheels based on the ROTORA BBK fitment.
#65
Just a Note: ROTOTA FITMENT FILE
Once you print the pdf fitment file from Rotora PLEASE verify that the dimensions were to SCALE... when I initially printed it, the dimensions were off by 9%... so I changed my printing options and set the file to print at 109% and everything worked out... remember that the dimensions are in milimeters (mm) and there's 25.4 mm to an inch = 25.4mm=1in
#67
See this link. It is pics from an Acurazine member (MichaelBenz) with a 3rd gen TL w/ front and rear ROTORA BBK's.
https://acurazine.com/forums/ramblings-12/those-who-know-watches-138689/
#72
Originally Posted by swoodle
Hey Josh. How about the Rotora BBK Front 1 piece (slotted only)? Are they in stock? What is the shipped cost to 31904? Thanks again
#77
1 Post
Im really interested in buying these, but I have a couple of questions
1. What is the difference between 1pc and a 2pc set?
2. What is the advantage of getting just slotted rotors instead of slotted/drilled rotors? and getting drilled rotors instead of slotted/drilled rotors?
#78
The 2-piece rotor does have its advantages:
- Aluminum hat w/ iron disc
- Cool more effectively due to less restrictive air flow
- Less prone to distortion/warping due to hat being separate from disc
- Hat can be reused so less cost on replacing rotors
2. If you have the slots you don't need the drills. The majority of BBK buyers do drilled and slotted b/c it looks nicer.
#80
Originally Posted by THE_FIRM_ENT
hey excelerate, if i was to purchase the kit can your store do the install as well and if so how much all together with a 1 piece front kit for a 05 TL?
