Type S - Winter Wheel Options
#42
6G TLX-S
howiedewitt (09-17-2023)
#44
I had Pirelli Sottozero 3s and the Continental Viking Contact 7s. Both were great tires on the Type S but I think the Sottozeros had slightly better dry weather traction.
#47
Anyone know what is the recommended tire pressure for the Sottozero 3's? My install didn't come with the spec sticker.
#48
Any recommendation for alternative tire sizes for 19? A preferable shop does not have any winters in 255/45/19. But there are couple good options for alternative 245/45/19. Any concerns going with those?
The following 3 users liked this post by GunnerX:
arek1200 (12-27-2022)
#55
6G TLX-S
If the hub diameter is 64.1mm and hole diameter is 72.6mm, then using hub rings is the proper way to go.
#57
yes they are the correct lug pattern (or else they wouldnt have gone on the lugs) manufacturers use the same wheels frequently and drill the lugs to fit. 5x120 is a wider pattern then many manufacturers use so they will be closer to the outer edge of the drillable hub area then if the same wheel was drilled to fit a 5x114.3 or a 5x105 etc.
#58
In general, are there different tire pressures for different rim/tire combos?
#59
They look great though! I goofed and should have bought the bronze version. They would have looked awesome with the blue!
#60
6G TLX-S
Therefore, if a new rim/tire combo has the exact same size/width/aspect-ratio parameters as the stock set, the recommended pressures printed on the door jam label should be used.
#62
The tire pressure is set by the factory according to the weight of the vehicle, the front to rear weight distribution of the vehicle, and the handling characteristic of the vehicle, for the existing size/width/aspect-ratio of the rim/tire combo.
#64
Nomad346 (02-19-2023)
#66
It kind of looks like a manufacturing error to me... if you compare the two rims below 18" and 19" , on a 19" rim the counter bores are way oversize for the nut size , machined on a incorrect pitch diameter (not concentric with the studs) and cutting into a center cap bore...poor machining and yet it passed quality control...just my opinion.
I found out that these are two different wheel models. The top is the FC04 and the bottom is the FC04A. The 'A' denotes wheels which can be drilled to different bolt patterns. That's why the bolts on the bottom wheel are off center.
arek1200 (11-27-2023)
#67
6G TLX-S
The top picture is a 5x120 bolt-pattern wheel drilled with a 5x120 hole pattern, whereas the bottom picture is a 5x114.3 bolt-pattern wheel drilled with a 5x120 hole pattern.
Do a search on the forum, there was a member who bought the same off-center (5x114.3 wheel with 5x120 holes) wheels. He said the nuts kept coming loose and also the nut seat area on the wheels were all messed up due to the nuts not able to seat dead center inside the holes. Definitely not safe to drive on.
Errowen
10-13-2005 08:23 AM
