Coilover options?
Coilover options?
So far ive seen bc and megan racing and a few others. None of these companies are reputable. For a 50k+? Car i want a good ride does anyone have any coilovers they can recommend? Ive called kw and rsr both have no intentions of making tlx coilovers
What is your intention for the usage? You doing canyon run or auto cross or track session? Or want better handling? If you want better handling just do springs. But if you do occasional canyon run or auto cross then coilover.
You can opt for stiffer spring rates which Swift Springs can customize at your spec but additional charge. Or standard spring rate which Eibach carries. It just comes down on what you looking for.
I have BC Racing coilovers. I luv them!
I'm running BC Coilover BR for about 2 years now. I haven't had issue of with ride comfort in the beginning. But after I adjusted the stiffness from comfort to medium setting since I do occasionally autocross and canyon run, ride quality still the same. Even on tight cornering, I don't feel any rubbing issue between the tires and fender. I don't daily as much but on weekend ride quality is good.
