2021 TLX 2.0 engine lights after engine water damage
Hi everyone, I知 new user. I have 2021 Acura TLX with 2.0 engine, I知 mechanic, changed time chain, crankshaft connecting rod, tensioner after water damage. After everything done engine runs perfectly, no noise drive good. In general car works good but I have check engine light, 2 codes P0341 and P0366. Drove about 800 miles and then
I removed the cover, checked the marks, all marks are in the correct position. I checked the camshaft sensors with a multimeter, the resistance is ok.
can you see live data and see if it's changing properly?
Noman Khan
08-08-2017 03:49 PM
