2021 Acura TLX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2021 Acura TLX Technical Service Bulletins:
TSB 20-034 - 2021 TLX: TQI and New Model Service Information
Applies To: 2021 TLX (2WD, SH-AWD) - Base, Technology Package, A-Spec, Type-S, Advance Package
http://www.urvi.net/forumfiles/SB/B20-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-034.PDF
TSB 20-035 - 2021 TLX: TQI of the Navigation System
Applies To: 2021 TLX - ALL with Navigation
http://www.urvi.net/forumfiles/SB/B20-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-035.PDF
TSB 20-036 - Service Manual Update: Passenger’s Frontal Airbag Removal
http://www.urvi.net/forumfiles/SB/B20-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-036.PDF
http://techinfo.honda.com/rjanisis/p...ag Removal.PDF (Link works, but is wrong)
TSB 20-049 - Service Manual Update: Pedal Feel Simulator Replacement
Applies To: 2021 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B20-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-049.PDF
TSB 20-053 - MIL is Flashing with Loss of Power
http://www.urvi.net/forumfiles/SB/B20-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-053.PDF
http://techinfo.honda.com/rjanisis/p...-053 Rev03.PDF (Link works, but is wrong) Version 3
TSB 21-007 - MIL Is ON with DTC P0455
2022 TLX - 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA004268
2022 TLX - SH-AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA002548
2022 TLX - SH-AWD Type S - From VIN 19UUB7...NA000001 thru 19UUB7...NA001734
http://www.urvi.net/forumfiles/SB/B21-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-007.PDF
TSB 21-021 - MIL Comes On With DTC P0236
Applies To: 2021 TLX - ALL (Except Type–S) - ALL
http://www.urvi.net/forumfiles/SB/B21-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-021.PDF
TSB 21-028 - MIL Comes On With DTC P061B
Applies To: 2021 TLX (2.0L) - ALL - ALL
http://www.urvi.net/forumfiles/SB/B21-028.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-028.PDF
http://techinfo.honda.com/rjanisis/p...1-028 Ver4.PDF (Link works, but is wrong) Version 4
TSB 21-032 - Popping/Crackling from the Speaker; Display Blank
http://www.urvi.net/forumfiles/SB/B21-032.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-032.PDF
http://techinfo.honda.com/rjanisis/p...1-032 Ver2.PDF (Link works, but is wrong) Version 2
TSB 22-002 - Front Brake Squeal When Applied at Low Speeds
Applies To: 2021 TLX 2.0L only - ALL - ALL
2022 TLX 2.0L only - Base 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA002135
2022 TLX 2.0L only - Tech 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA001605
2022 TLX 2.0L only - Tech Advance 2WD - From VIN 19UUB5...NA000001 thru 19UUB5...NA001549
2022 TLX 2.0L only - Base AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA001569
2022 TLX 2.0L only - Tech AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA001231
2022 TLX 2.0L only - Advance AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA001203
2022 TLX 2.0L only - Tech Advance AWD - From VIN 19UUB6...NA000001 thru 19UUB6...NA000959
http://www.urvi.net/forumfiles/SB/B22-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-002.PDF
http://techinfo.honda.com/rjanisis/p...2-002 Ver3.PDF (Link works, but is wrong) Version 3
TSB 22-007 - Emissions Recall: 2021-22 TLX Type S PGM-FI Software Update
Applies To: 2021-22 TLX - Type S - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-007.PDF
TSB 23-010 - Software Update DTC P0300, P0301, P0302, P0303, P0304, or P0172
Applies To: 2021-2023 TLX - ALL (Except Type S) - ALL
http://www.urvi.net/forumfiles/SB/B23-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-010.PDF
TSB 23-030 - 2021–23 TLX Popping/Crackling from the Speakers; Display Blank
Applies To: 2021-23 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-030.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-030.PDF
TSB 24-016 - Safety Recall: 2021 TLX Seat Weight Sensor (DTC U3000-49)
Applies To: 2021 TLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-016.PDF
TSB 24-021 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Stop Sale
Applies To: 2020-21 TLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-021.PDF
TSB 24-023 - Safety Recall: 2020–22 Multi-Model Seat Weight Sensor Campaign Notice
Replaces the campaign notice dated February 27th.
NOTE: This notice is to keep all dealers with the most up-to-date information for this safety recall. Dealers will be notified when this notice is revised.
http://www.urvi.net/forumfiles/SB/B24-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-023.PDF
