TLX Center Bore Size
Old 05-15-2016, 08:12 PM
sillyjav's Avatar
Hi, i believe the TLX center bore size is 64.1mm. When buying after-market wheels. Does the aftermarket wheel HAVE to have an exact same center bore size?
Old 05-15-2016, 10:43 PM
csmeance's Avatar
Received 2,004 Likes on 1,424 Posts
If the bore is smaller the wheel will not mount. If the hub bore is larger you'll need to buy some hubcentric rings to ensure there is no space between the hub and the wheel's hub.
The TLX uses hubcentric wheels meaning the weight is supported by the hub and it's center is found via the hub. Other wheels can be lug centric in which the lugs help find the center of where the wheel should be.
If you don't use the adapters with a larger bore, you'll get a nasty vibration and can snap off wheel studs.
sillyjav (05-16-2016)
mlody
12-04-2019 02:11 PM
Rae Rad
07-30-2016 05:58 PM
neil0311
04-16-2016 03:59 AM
rocket_pup
04-04-2016 10:24 PM
Quick Reply: TLX Center Bore Size
