Back to OEM size?
Old 04-02-2018, 02:24 PM
SuperSaiyanTLX's Avatar
Back to OEM size?
2017 TLX 2.4. I've been using 235/45/17 tires on XXR 530 wheels (17x8.25) for 2 years on my TLX. The tire and wheels previously came from a 2007 Type S. It's time for a tire replacement. Would there be any advantage to going back to OEM tire size for the TLX? Better gas mileage? Comfort? I'm averaging right about where the car is rated for gas mileage and I don't drive aggressive.
Old 04-02-2018, 02:32 PM
Received 16,260 Likes on 11,971 Posts
the 235/45/17's are smaller in overal diameter and circumfrence...this will affect your speedometer and ultimately miles driven.
the speed variance is 5% too fast!
https://www.1010tires.com/Tools/Tire...ismetric=False
Old 04-02-2018, 02:34 PM
you can still use a 235mm wide tire if you wish...just choose a different profile height
Old 04-02-2018, 02:36 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
I think your car had three different wheel sizes available from the factory; assuming you're referring to an OEM size of 225/55 R17, moving back to that size *may* yield a very minor improvement in fuel economy; so small it may not even be measurable. That said, the 225 series tires may well be a bit quieter and will definitely be able to slice through snow a bit easier.
Sgt128
3G MDX (2014-2020)
02-23-2014 09:39 AM
AcuraTLG3
01-16-2011 08:49 AM
3zeroCL
09-05-2010 11:47 PM
Scrib
05-30-2003 02:57 PM
Quick Reply: Back to OEM size?
