Notices
2018 TLX Aspec AWD Tire Question
Old 06-16-2019, 06:06 PM
Registered Member
I have a 2018 TLX Aspec AWD. Today while washing the car I noticed that my driver's side front and driver's side rear have bulges in the tire. The bulges are located in the sidewall. I am willing to bet this is a result of hitting a pothole, but I'm note entirely positive. I did a quick google search online and it sounds like I need to replace both tires because this is extremely unsafe to drive. My question is do I have to replace all four tires or can I get a way with only replacing two? I only have just under 20,000 miles on all four tires.
I thought I remember reading when buying the car that the rear tires are slightly wider than the fronts. Is this true? Or am I misremembering this? If this is the case, I would assume that confirms I need to replace all four tires.
Thanks in advance for any help you can provide.
AcuraFan82 is offline
Old 06-16-2019, 06:46 PM
Registered Member
KeithL's Avatar
The tires have a warranty from the tire manufacturer, give them a call.
KeithL is offline
Old 06-17-2019, 07:45 AM
Registered Member
Yes call the tire manufacturer but this is why I am amazed that car manufacturers continue to equip cars with these low profile tires that cannot hold up with the terrible conditions on many roads.
I really wanted to lease a 2018 TLX Aspec AWD but living in New York had to pass due to the 40 series tires and ended up leasing a Tech AWD with 50 series tires. While I am very careful and avoid most potholes they do sometimes appear out of nowhere and I have been happy on several occasions to not have had any issues after hitting several.
Then Acura for 2019 for some strange reason outfitted all 6 cylinder AWD models including the Tech and Advance with the 40 series tires. As much as I enjoy my 2018 I would not consider a TLX with them.
Pens Fan is offline
TSXV6Guy (06-18-2019)
Old 06-17-2019, 02:48 PM
CPR
Registered Member
CPR's Avatar
As far as I know, Michelin, will NOT warranty tires with bubbles from potholes; tire insurance will
In NYC, insurance should be mandatory, because the streets are piss poor
CPR is offline
ablb454
14
04-12-2019 11:13 AM
TSXV6Guy
Fifth Generation TLX (2015+)
47
02-09-2019 06:38 PM
Mr. ShawnJ007
26
07-05-2018 08:18 AM
Katira
34
06-20-2018 08:25 PM
Sloppy305
05-15-2017 06:20 PM
Quick Reply: 2018 TLX Aspec AWD Tire Question
