19" Enkei TY5 Hyper Silver on 2017 Acura TLX
Planning on getting 19" Enkei TY5s on my white 2017 Acura TLX V6 P-AWS.
TY-5 | Enkei Wheels
What offset and bolt pattern would you recommend for my car?
Here is their size chart for this wheel:
http://enkei.com/wp-content/uploads/2015/11/TY-5.pdf
Also, I am not planning on lowering my car anytime soon unfortunately, so what would you recommend for tire size?
Thanks for the help fellow TLX owners !
TY-5 | Enkei Wheels
tire size; you always want to keep OEM diameter to keep speedometer and mileage as spot on as possible.
to do this; use a tire calculator and input stock specs to compare with proposed tire sizes...the calculator will spit out results. keeping in mind that you dont want to deviate more than 3% in either direction.
my favorite tire calculator is:
Tire Size Calculator - Tire & Wheel Plus Sizing
19 x 8.5 +35 would be good. Would push the wheels out so they don't look sunken in as much.
do you have a pic or link with anyone on this setup? I saw someone post a pic on stock height with 19x8.5 +45 and the fronts looked pretty flush. the backs didn't look as flush though. So I'm thinking +35 might push the fronts out too much but back might be perfect. This is all assuming camber within factory specs.
