Getting into back of Seat???
Hi
I need to open up the back of my drivers seat so I can perform a lumbar support mod. I did the same thing on my toyota highlander as it was just a matter of unzipping the back of the toyota seat itself. Unfortunately the TLX seat does not have something as simple as a zipper to open back of seat!!! I DID unhook that flap at the bottom of back of seat but didnt know where to go from there. Someone mentioned in a TL thread that you "pull towards you then pull up"
I have this feeling the seat back cover sits in a very tight grovve/track ??
thank you
thank you
Originally Posted by rockstar
Back of seat comes off like this:
pull bottom part TOWARD YOU (2 clips)
Then lift entire thing UP toward roof of car, it'll lift off.
be warned though, those clips will break, and it's a BIATCH to get them to line up and hold tight, even with new ones.
On my black car, I drilled a pilot hole and had a small drywall screw holding it in at the bottom where you couldn't see it.
Wow seems like a PITA to do this
my highlander has a zipper and that's it
so you DO pull and push up?
the dealer made it sound like u had to remove entire seat
maybe I just use a foam roll.... Unbelievable
Summer is Coming
I've taken a Honda seat back off and it was attached with plastic tabs and slots. Hard to explain, but I broke one taking it off and it never went back on the right way. Plus there is an air bag in there so I'm not sure I'd be messing around with mine. There are a lot of after market lumbar pillows you can buy.
Ricky Her
2G CL Problems & Fixes
06-18-2016 08:09 AM
