Acura speed vibration/shake
I just got an v6 acura tlx shawd with 60,000km on it (first car ever) and I couldn't help but notice that when I reached 120/140kph that there was some sort of vibration, I'm not really mechanic savvy at all, wondering if I'm in any danger behind the wheel of this vehicle, note this car was straight from the dealership and had a safety check
Take it back
Know design issue with the AWD TLX. See "vibration issue" topics in this forum.
Basically, the car resonates under certain conditions, depending on the rear differential / propeller shaft alignment tolerances (and probably other issues). This will never be fixed. Either lear to live with it, or try to return the car if your dealer will let you!
I think the car's chassis is prone to vibration - and then it depends on how much the specific parts installed. Look at some of the other threads and the service bulletin and you will get a better understanding. Even honda engineers can't seem to fix the problem.
mojo_79
5G TLX Problems & Fixes
92
11-25-2017 07:52 PM
