Weird Errors After Battery Runs Out
Old 08-30-2015, 10:32 PM
chrisr's Avatar
Hi. Here is the sequence of events that let to my issue:
-Ripped around 8 CDs on accessory mode, with engine off.
-Battery ran out.
-All sorts of errors appeared. I am unable to start the car.
-I jumpstart the TLX with my van.
-The care is able to start.
-I do however get 2 errors on the MID: (1) emissions system problem and (2) Electric Parking Break Problem
-It seems with these errors, the car still runs.
What happened here? What do I need to do?
Old 08-30-2015, 10:33 PM
chrisr's Avatar
Old 08-30-2015, 10:36 PM
Received 16,260 Likes on 11,971 Posts
Old 08-30-2015, 10:52 PM
tlxsteve's Avatar
-Battery ran out.
Take it in.
I had the same issue without the power failure. Car ran fine while I waited to take the car in. Had the issue about 2 weeks after picking up the car. Haven't see the issue since. I have 17K+ on the car.
Good luck.
Old 08-31-2015, 05:27 PM
sbillard's Avatar
I did the same CD ripping ritual as you, got the same Christmas Tree of lights.
Next morning I jumpered the car to my wife's and started it up. Then took a long drive to recharge the battery.
Moral of the story is keep the engine going when you rip CDs. The car does not like low batteries.
Old 08-31-2015, 05:41 PM
Quandry's Avatar
Similar story here listening to music while checking out all the settings. My battery did not handle the drain well and had to be replaced as it wold no longer hold the charge.
Moral of the story #2 is new batteries also need a break in period.
Old 08-31-2015, 05:49 PM
Moral of the story #3, batteries dont need break in period.
Acura branded batteries are weak. install sears die hard platinum series.
Old 08-31-2015, 08:24 PM
Quandry's Avatar
^ Maybe this will explain what happens to some of them. Not strictly a break in period but initial handling:
What Causes Car Batteries to Fail? ? Battery University
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
scionxb3003
09-14-2015 01:52 AM
Big mo
4G TL Problems & Fixes
09-12-2015 07:22 AM
Phambam12
09-06-2015 06:57 PM
Quick Reply: Weird Errors After Battery Runs Out
