Help!!!
Old 10-04-2017, 08:55 PM
joneswood's Avatar
Help!!!
I leased a brand new 2018 TLX A Spec AWD (Black with Red Interior). Had it about a week or so with less than 400 miles on it. Tonight, I pull in my driveway, put on the brakes, then finish a phone call. About three minutes later, I get an error for the cruise control. Then, errors for transmission, emergency break, breaking system, off road mitigation system, impact warning system and two or three other systems flashed. The car starts, but will not go in gear at all. Road side assistance came, but said he couldn’t tow to the dealership (needed a flatbed and that might not work).
I traded out of a 2015 TLX that never gave me an ounce of trouble. Confused and frustrated. Need some advice before anger takes over.
Old 10-04-2017, 09:18 PM
pyrodan007's Avatar
Sounds like it may be a low battery issue. Rings a bell with other TLX years having the same problem. Scary though, stupid reaction from car.
Old 10-04-2017, 09:22 PM
theredia92's Avatar
I have seen this exact thing happen to a handful of Honda/Acura products. Usually within the first 1000 miles.Most likely a glitch in the computer system. First thing I would do is disconnect the battery for a few minutes to reset the computer. If you do that and still get the messages, the car is going to need to go to the dealer for further testing. Like I said, I seen this a few times before and its never been anything serious.
Old 10-04-2017, 10:31 PM
6 Forward 1 Back
Speed_Racer's Avatar
I've seen two times where people had those same symptoms on new ASpecs. Ended up being a blown fuse for the battery fan. I didn't even know the battery had a fan. Lit up the dashboard like a Christmas tree and wouldn't let you go into Neutral.
Old 10-04-2017, 10:33 PM
6 Forward 1 Back
This was the first time I'd seen it.
Old 10-05-2017, 12:01 AM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
It's That Kind of Thrill
The following 4 users liked this post by AZuser:
atomlinks (10-08-2017), justnspace (10-05-2017), slimm1469 (10-14-2017), teh CL (10-07-2017)
Old 10-05-2017, 04:15 AM
joneswood's Avatar
The video is exactly what’s happening with my car. Tow truck can’t get it. Have to have dealership come to my house. What if this had happened on the road 100 miles from home? Is there a quick way for me to fix this?
What if it happens again. This is extremely frustrating for a brand new car.
Old 10-05-2017, 06:41 PM
Rocketsfan's Avatar
FYI, the fireworks display where it shows nearly everything failing seems to be a symptom of various things on this forum. It's happened to me a couple of times about 6 months apart in my 2015 TLX (not a SH-AWD) and back then it was related to the actuators being the culprit. Others have had it happen and it ended up being something else. In my case and others, the car went into limp mode. "Luckily" it happened to me while I was still in the city limits because I'm not sure what I'd do if I was out on one of my roadtrips. Speaking of which, I need to join AAA. lol.
If anyone else is reading this, don't just assume that turning the car off and back on again and having all the errors disappear means "it's ok to drive". When it happened to me, I turned the car off and restarted it about 3 or 4 times if I recall before the errors went away, but like I said, there were still real issues that needed to be repaired despite the fact it seemed like the errors "went away".
Good luck and come back and post what the issue(s) ended up being.
Old 10-06-2017, 05:54 AM
joneswood's Avatar
My issue seems to be the blown battery fan fuse. Sorry for taking such a long time to post. Two concerns: 1. Is this going to be a recurring issue and 2. The way the situation was handled. Here's the chronology:
Wednesday Night:
8:20 called roadside assistance
8:30 called dealership (10 mins. from my house) they told me to pick up a loaner when tow truck arrives
9:05 tow truck arrives and explains they can't tow a AWD the won't go in neutral - sending flat bed
9:15 pick up loaner
10:00 call roadside back to get status - they inadvertently cancelled the truck sending another
11:00 call roadside again. They state they made a mistake and that the car can't be towed at all if it can't go in neutral. Also, said dealer would have to come to my house to fix the car (WTF)
Thursday morning:
7:30 AM: at dealership. They tell me to go home and put car in "car wash mode". I explain it wouldn't work they said it would
7:45 try car wash mode. It doesn't work.
Had a work responsibility from 8-9:30
9:30 called roadside at dealership - they said truck with dolly needed and didn't know why it wasn't sent last night. They will expedite.
9:35 . dealer advises that they have a preferred tow truck that they trust. Advised me to cancel roadside - I did
10:45 dealer tow truck arrives and says he can't do it and call roadside
11:00 call roadside
11:45 tow truck arrives and takes car in 15 minutes
5:00 dealer tells me what's wrong and that car will be ready next day
DT_ASPEC (02-06-2018)
Old 10-06-2017, 09:58 AM
Received 8,584 Likes on 6,630 Posts
what... a shitshow..
Old 10-06-2017, 10:07 AM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Damn,all that trouble you had to go through.
Old 10-06-2017, 11:21 AM
pyrodan007's Avatar
And then people wonder why Acura is not among the best on surveys or service lists. It's for shit like this, very un-luxury or even premium like.
Old 10-06-2017, 05:46 PM
_
AZuser's Avatar
Is the reason why it wouldn't go into neutral because of the electronic push button gear selector?
Old 10-07-2017, 02:44 AM
joneswood's Avatar
I suppose that the blown fuse throws off the entire electrical system. Anyone know if this may be a recurring problem? Also, should I press Acura or dealership for some type of compensation?
Old 10-07-2017, 01:43 PM
joneswood's Avatar
Picked up my car, today and all seems well. The dealership stepped up and overall responded pretty good, except for the screw up with their tow truck (but that was done to try to expedite). However, Acura roadside screw ups ended up costing me 1/2 day of work.
Will keep updates if anything changes.
Old 10-07-2017, 01:50 PM
Null and proud of it
Midnight Mystery's Avatar
Electronics are stupid....
Old 10-07-2017, 02:00 PM
_
AZuser's Avatar
In other words, traditional gear stick shifter(s) FTW!
The following 2 users liked this post by AZuser:
JM2010 SH-AWD (10-19-2017), teh CL (10-07-2017)
Old 10-07-2017, 02:56 PM
Yeah, TLX has push button shifter....
Wouldnt that be something, push R then car lurches forward…
I do want push button start though...
Old 10-07-2017, 03:45 PM
6 Forward 1 Back
Man, what I wouldn't do to see that in my TLX. . .
Old 10-07-2017, 04:01 PM
_
AZuser's Avatar
*cough* 2018 Honda Accord 2.0T Sport *cough*
Old 10-07-2017, 06:48 PM
joneswood's Avatar
Gotta admit I would love my TLX with a manual transmission. Other than that, I like the push button selector (except when the damn thing broke). I got used to the push button pretty quick and not appreciate the ergonomics of the car and simplicity. Plus manual would guarantee wifey doesn’t drive it.
Ine last thing, my loaner was an MDX. Love that vehicle.
Old 10-07-2017, 09:19 PM
_
AZuser's Avatar
That's a bad thing?
Old 10-08-2017, 06:13 AM
joneswood's Avatar
Nope, good thing! Wasn’t clear on that. Don’t think she would either way. Strange taste. She has a new Murano, but didn’t like the MDX. Go figure. Again, I’m not fond of SUV’s but I could drive the MDX, really enjoyed it.
Old 10-08-2017, 09:29 AM
quantum7's Avatar
I will testing out one of these (MT) in November when they arrive. Might be a great option.
Old 10-08-2017, 11:42 AM
I just saw a video of it last night... I love the torque of my RDX, my TL just doesn't have it...
I feel pretty optimistic about the 2018 Accord!
Old 10-09-2017, 01:41 AM
joneswood's Avatar
In an automatic, the traditional shifter is really not necessary. The push button allows for more space and better ergonomics.
Old 10-09-2017, 12:03 PM
6 Forward 1 Back
I'll wait until they come out to check out. I don't know how that will be without an LSD. I'm spoiled by the SH-AWD.
Old 10-14-2017, 09:28 AM
slimm1469's Avatar
I've wanted to buy a TLX since 2015. I've had multiple test drives, they were great! I love where the car is positioned in terms of an affordable, lux-ish, sport-ish car! I love the looks, the interior! But every time I get in my homely 9-yr old Accord, it starts, it runs, it does what it's supposed to do. Hard to walk away from that. Maybe I'm a wuss and this is the future of driving, I dunno.
