3.5 mm auxiliary port questions
Subscribe
Apr 15, 2018 | 03:27 PM
Hello all,
2018 TLX Tech and I use Apple carplay with my phone mostly but I also want to hook up an iPod as another audio source using the 3.5mm port which is inside the storage center armrest. The iPod connects with a lightning connector. Is there such a cable that will both charge and play audio when hooked up to the 3.5mm port?
i have found several cables with a lightening connector on one end and 3.5mm on the other end, but none give a clear indication if they charge AND play audio. Does anyone have any experience or suggestions if it works and the brand? Thanks
Reply 0
Apr 16, 2018 | 06:12 AM
No, you cannot charge an iPod via the 3.5mm headphone jack. Instead, simply install a phone charger in the center console, then attach a usb to lighting cable to keep the iPod charged. Finally, attach a 3.5mm to 3.5mm audio cable to the aux port and iPod.
This is will require manual control of the iPod.
Reply 1
Subscribe
