VCM Related vibration corrected
[QUOTE=someguy11;16429366]
A. If the vehicle is under warranty, I would recommend removing it. There’s no practical reason why Honda would void your warranty for using the device, but any modification to the vehicle can be used as attempted grounds to void the warranty by some unscrupulous dealers/QUOTE]
Be certain Honda will use whatever they can against you, in case of a Court case. Among other things, they blamed it on TARDIM's low profile tires. They are not willing to recognize the situation. They will systematically revise each and every line of information they can put their hands on. Any modification is a reason they'll exploit to put a dought in a Jugde mind. So far, it did benefit them. I hope it changes after I'll go to Court.
What?
After getting my transmission replaced, I noticed at certain points a pronounced vibration, reminiscent of lugging the engine by being in too high a gear with a manual transmission. This occurred primarily when the VCM kicked in and the RPMs were 1300 - 1600. It did happen once or twice without the VCM kicking in, as well, at about the same RPM range. At first I thought this was just a feature of the new transmission, but then I read a post here by one other person who reported the same phenomenon and it turned out to be a bad front engine mount
I took it in to Acura and said, I would like to get this fixed since I am almost out of warranty, and here's what I think it is. They took it in and after several days and multiple calls to TechLine got it corrected. My engine mounts were all reporting they were working fine, but still the vibration was there. The key to fixing the problem was a process called "neutralizing" the engine mounts, and the first time they tried it, it didn't work. Apparently the car has to be in gear when the procedure is done. Anyways, now the car is smooth as butter when the VCM kicks in, the way it was before I got the new transmission.
Just wanted to share that in case anyone else is experiencing this issue.
TSX1012m6
Oct 27, 2017 10:30 AM
FamusFace
Jun 16, 2007 10:04 AM
