For those with a TLX with remote start
Does it have an option for Winter or Summer start? I would like to start it in winter and have the heated seats turned on max and the heat blasting to warm up the car.
Is there any type of setting that allows what the TLX does when its remote started? |
I would expect it to use whatever settings you have when you turn your car off set to.
my SWAG |
Originally Posted by insanik
(Post 15127804)
Is there any type of setting that allows what the TLX does when its remote started? The climate control is automatically set to 72 degrees, pre-conditioning the TLX interior to a comfortable temperature. In cold weather, seat heaters activate while the defrost function works to clear the windshield. |
Originally Posted by jayb082
(Post 15127811)
I don't have one but did research as I plan to get it as an accessory. Acura site explains the following:
The climate control is automatically set to 72 degrees, pre-conditioning the TLX interior to a comfortable temperature. In cold weather, seat heaters activate while the defrost function works to clear the windshield. Awesome. but what makes the vehicle know it's winter time to turn on the heated seats and defroster? |
^^ Outside temperature gauge?
(Post 15128294)
Um....it's a LOT colder than 72°F inside the car?
Originally Posted by Gregg
(Post 15128343)
Exactly...And if sensors inside the car can determine when the interior reaches 72°F, it's not a huge stretch that the sensors also can determine when the interior is at 25° or 30° or 40°F and flip on the seat heaters and defroster when the remote start controller brings the car to life.
This is one of my favorite features of the Advance trim... along with the ventilated seats. And with the 1/2 mile range on the remote it will certainly be cool in the car when I open the car.
Hopefully once in the car the driver only has to step on the brake, hit the start/stop, shift and go. I hope it doesn't actually re-start like other Honda's do. |
That's exactly how you do it. From the installation instructions:
1. Press LOCK, then press and hold ENGINE. The amber LED blinks, and the green LED stays solid for one second when the engine starts. You can repeat this once at any time within 10 minutes of the initial remote start for a 10-minute extension. 2. While remote engine start is on: • The climate control system can warm or cool the interior, depending on the ambient temperature. • The security system remains on. • Exterior lights and accessories remain off. 3. To start driving after you enter the vehicle, depress the brake pedal and press ENGINE/START/STOP |
Originally Posted by Rocket_man
(Post 15129029)
I see on the Acura site under TLX features that the range is up to a quarter mile but when I build a 2.4 it says the Remote Start accessory has a range of 328 feet. Anyone know which is correct? Maybe 328 is supposed to be 1328 (I hope!)... that's about a quarter mile.
(Post 15129029)
Hopefully once in the car the driver only has to step on the brake, hit the start/stop, shift and go. I hope it doesn't actually re-start like other Honda's do. Lock Remote Start get to car Unlock Go Though just about any Honda/Acura before that (and, afaik, the accessory versions, too) shut off the engine when you unlock the car. |
Originally Posted by TLXTim
(Post 15129097)
Is there an app for iPhone or android that can be used to start the car with acura link?
No, you can't start or stop as best I can tell. You can lock/unlock as well as get performance info / fuel levels / etc with the "Connect" package
http://www.acura.com/AcuraLink/packa...tion&model=TLX Definitely not cheap.... |
Now that I have my TLX and have setup my AcuraLink, I can verify that you can lock and unlock the doors via the AcuraLink Connect app as long as you have "Connect" or "Premium" packages.
You cannot, however, trigger the remote start. |
(Post 15130582)
So after playing with the remote start. it does not adjust heating, cooling, or seats based on outside temperature. it just goes on the last settings the car was on before it was turned off
(Post 15129029)
Hopefully once in the car the driver only has to step on the brake, hit the start/stop, shift and go. I hope it doesn't actually re-start like other Honda's do. My TLX did not restart. I just hit the brake and pressed the start button and shifted. That just lit up the dash and everything and i shifted out. Smooth transition. no restarts at all |
The TLX brochure states that range is up to 800 METRES (over 2500 feet). That's half a mile. Abut depends on the number of obstructions. All Hondas for some time have automatic climate control setting depending on outside temp. On Hondas it will set the climate control to 21 celsius, and turn on windshield defrost and rear defrost as long as the car's HVAC has been left in "Auto". It will only switch on heated seats if they have been left on beforehand. I guess why the heated seats are now part of the touch screen maze.
The Honda II remote start claims a range of 400 to 1500 feet depending on stuff in the way. Evidently the TLX remote has much more oomph. I am not clear about uwing the TLX remote without killing the engine on entry but the Acura salesperson sqid there was a way to get in a move off without it stopping. |
(Post 15160762)
I can confirm that the range is pretty nice, I can start my car from my desk on the 8th floor in the office when the car is parked on the far end of the parking lot.
I also noticed that when outside temperature is around 40-50F the windows get foggy with the remote start and it takes another 2-3 minutes for them to clean up once I get into the car. |
Originally Posted by sstfnv
(Post 15161080)
