Sooo.... I just updated my TLX software by accident!?
I went to developer mode as usual to turn off ANC and I hit VERSION DOWNLOAD ... The unit completely shut off and came back on and started downloading for about 5 minutes.
https://i.imgur.com/Hj4ODfz.jpg
Then when it finished it rebooted and said "initializing" and then reboot.
Here are my new version numbers. What do you guys have?
https://i.imgur.com/slU85TL.jpg
All my normal saved settings have reset to factory and things seem a bit snappier
Doesn't you ANC stayed turned off when you set it? I seem to think it resets when you get back into developer/diag mode because my music stays excellent for two days after the initial turn off of ANC.
Just like a latest Windows PC, there is a partition inside the hard-drive where the "rescue/repair software" is stored.
If the operating software is screwed up, then the user can reload the "rescue/repair software" into the main partition of the hard-drive to restore the operation software to it's initial settings.
So it is likely that this "rescue/repair data" for the system is stored either on the hard-drive, or in a flash ROM inside the head unit.
I actually just did this same exact thing, but when the unit came back up it required the nav code to get back into it. I looked through all booklets and papers that came with the car and I couldn't find the code anywhere. It did give me an option that said press and hold the audio button and it would automatically enter the code, but that didnt work. I ended up having to drive to my Acura dealer and have them fix it! But at least now I have my code for if it ever does this again.
Wouldn't a Thanks button be easier?
Ponsey_Scheme
Oct 23, 2015 09:16 PM
