Rear Passenger Door Won't Unlock/Lock
I have a 2017 Acura TLX and the rear passenger door stopped unlocking/locking yesterday. It happened a few months ago but started working again. Does anyone know how to fix this?
I've read somewhere about the fuse being blown. I've tried finding the fusebox but it's hard to find, not sure if I have to pull a panel off. I'm also not sure which fuse to check either? If found a list of fuses on this website https://car-fuse.blogspot.com/2021/0...-fuse-box.html. It mentions Rear driver door lock but not passenger rear door lock??
Rear lock/unlock
[Our 15 MDX advance does the same thing. Will lock/unlock when it wants to, and you can tell because there is no beep from it when walking away. Also, remote start and rear hatch won’t work via remote with one unlocked door. This happened years ago, but it began working fine, until now.
Did you ever find an answer to get it working again?
Thanks!
QUOTE=grisham312;16816093]I have a 2017 Acura TLX and the rear passenger door stopped unlocking/locking yesterday. It happened a few months ago but started working again. Does anyone know how to fix this?
I've read somewhere about the fuse being blown. I've tried finding the fusebox but it's hard to find, not sure if I have to pull a panel off. I'm also not sure which fuse to check either? If found a list of fuses on this website https://car-fuse.blogspot.com/2021/0...-fuse-box.html. It mentions Rear driver door lock but not passenger rear door lock??[/QUOTE]
Thanks!
