Probably going to get an Audi A4 instead of TLX
#161
So, if I start the car, and always do a little gentle driving first, I can switch to "fun mode" and do a little hard accelerating say, half the time I drive, and still get 200,000 miles from the engine, if I didn't get one with an unlucky QC problem from the factory? (Assuming I do all the recommended maintenance, OEM oil + filter OK?)
90% of my driving is not in "Sport+" mode, so even when I press the accel down, I don't think I'm running at redline much at all. Not every day, but sometimes a couple/few times a day, I like to floor it when going from 35 MPH up to ~80MPH on an on ramp, etc. I don't think my car's even been over 100MPH yet, though I would gladly see what 150 felt like on an open road, if I knew there weren't any cops nearby.
One thing to consider in regards that, is that the transmission won't even use the highest gear until about 80, right? (I'm guessing, I actually don't know - I just know that cruising at 80 MPH and sitting at ~1,500 RPM is cool, and saves gas) I've heard people say that the transmission is designed for "Autobahn type driving", so, if I had to guess, I would say that the TLX actually would be a decent car for Autobahn driving, just not if you want to race people :P
Originally Posted by BEAR
Is the Honda engine designed for sustained high speed Autobahn type driving? I don't think so,,,
#162
Received 2,600 Likes
My post referenced the review not the reliability ratings. As to 2018 any ranking could not based on the 2018 model whicb was released in late May. The reliability ratings were published in December and most likely finalized 4 months prior There’s not sufficient time available to incorporate survey data on the 2018. Any movement in the rankings was caused most likely by other cars getting better scores in the last survey data pull.
BTW the chart did not make it to the hard copy magazine when the chart was posted its in the Feb 2018 issue.
Look you can disagree with the numbers, the method, the weighting, whatever, fact remains 2016 2017 2018 comprise the 3 year study base. If you want to cancel 2018 from your mind 2017 was only 4 places better, not a great performance even if it was up another 4 places over that. This is a brand that was a perennial top 10 finisher.
Some say that the perception is good. They don't choose to remember that Honda has not built a good transmission in over 20 years. That's going back to the class action suits that Honda lost in the late 1990's. Money paid out, extended warranties, transmissions replaced (my daughters Accord EX AT, my TL 6MT). Take a look here at the TSB section & see what issues are out there. It take breaking legs or threats of suites to get Honda to issue a TSB so they don't come easy as they can damage the perception if people looked.
Bottom line is a lot of people who bought the car, a way more then the 20 or so who post here, did have issues. So while everybody here has a great car some other owners are not happy
#163
#164
Perhaps the survey you completed will be used for the 2018 ratings. The following is directly from CR. I happen to be a subscriber.
The Consumer Reports latest Annual Auto Reliability Survey, gathered information from Consumer Reports subscribers who collectively owned or leased more than 640,000 vehicles, from model years 2000 to 2017, covering more than 300 models. More information can be found at www.consumerreports.org and in the December 2017 issue of Consumer Reports magazine.
Will have to disagree with you my car was built in April its a 2018. I filled out the CR survey in November. Why would it take 4 months to sort numbers from an electronic document?
#165
As far as reliability, Audi in the US has the stigma from the 90’s, times have changed and the Audi reliability is extremely good nowadays, (can’t say the same about honda/acura/toyota, which were king of reliability in the 90’s, but not so much lately, still good and fine, but not as good as it was back in the day).
**Cough - had to use GM synchromesh on 1992 GSR to fix the 3rd gear grind. Decades later, I still have to remind myself to make sure I change the tranny fluid and pressure switches on 2008 TLS every 20K miles.
If your talking about money, why not get a Honda Accord rather than an Acura TLX.
BEAR-AvHistory (01-28-2018)
#166
Well, a sample size of 1 is not that useful statistically, but, I'll happily report back each year
I've never owned ANY brand of car that had zero problems, other than my current Acura TLX. I knew some guys that had some old Mercedes that seemed to never have anything go wrong, but all three Toyotas, every VAG, and even my Volvo and old Honda CRX each had at least SOME kind of problem beyond "routine maintenance".
My dad did own a Toyota Camry that was trouble free for over 10 years, other than the exhaust system rusting badly.
What I really want to know, is how much faster will I have engine troubles if I drive my car hard and push the pedal to the floor on a regular basis? Can the Honda/Acura J35 regularly see 6,000+ RPM and still run solid and smooth for years (as long as you do all scheduled maintenance and use decent gasoline)?
I had a 2003 V6 Accord 6MT coupe back in the day, and id hit the rev limiter in that car often. I drove the piss out of that car until she was totalled. I don't remember the mileage but I believe it was at about 240000km or 150k miles. Never skipped a beat. Never burned a drop of oil.
the 4G TL with the 3.7L did have oil consumption issues. But it was not typical of the J series family. From what I've heard, Honda bored out the 3.5L to 3.7L and coated the cylinder walls with some magic shit... engines that weren't broken in properly ended up consuming oil. I believe those engines were supposed to broken in fairly hard, as opposed to babying them for the first 1000 miles or whatever. Not sure if any of that is true (Never owned a 4G and never will, so i never bothered looking into it more). Though I haven't heard anyone having oil consumption issues in the TLX. I wouldn't worry about it and just drive it and enjoy it. You literally have nothing to worry about. These engines are "appliance" engines- and that's not knocking them. They're intended to require very little and last very long.
The following 2 users liked this post by TacoBello:
Christopher. (01-29-2018),
F23A4 (01-29-2018)
#167
This is the CR note at the bottom of the chart I posted:
Note: Alfa Romeo, Fiat, Jaguar, Land Rover, Maserati, and Smart are not included due to a lack of sufficient data
Editor's Note: This article also appeared in the February 2018 issue of Consumer Reports magazine.
Expect this is current updated data over December since the sample size from some 2018 makes was too small to make the cut. Either way take it for what its worth we are not debating who won, even the BMW's dropped a place. So be it.
The opinions are what real people who put their money into the car buy filled out the forum & sent it in.
#168
Eventually they copied the GM fluid or changed suppliers to get it. Things quieted down on the 3G site till they started to fail again. The GM synchromesh fluid just cover up the problem & was a band-aid that sometimes worked. Eventually they solved the problem by not offering a 6MT in the TLX.
There was a similar issue with the 4G 5AT's. They had failing torque converters in a lot of cars again fixed under a TSB not a recall so many were most likely missed.
#170
I definitely get where you are coming from - I'd like to go crazy and buy a new car now but would gladly wait if I thought Acura could pull out of their current sedan situation. They definitely had great cars in the past but the 4G and the TLX aren't giving me much hope that they can turn on a dime.
My favorite car of the show was the Audi S5 Sportback. It was in a really cool grey color only offered in an S..I think it was Daytona Grey..beautiful color. I was leaning towards an A4 for my next car which they had in the Black Optics package, but I thought the Sportback was a really good looking car. There is a lot of plastic going on, but the technology stands out.
#171
I was able to get a good look at some models I've been hoping to see before going to the dealer yesterday at the Philly car show. The show was packed as usual. Audi, BMW, KIA, and Honda all had good crowds. Audi was packed and it took a long time to be able to sit in cars. Acura wasn't very crowded when I was there. I was walking around the A-Spec and heard an early 20's female say to her father "this grill is hideous..the logo is way too big". . I just chuckled to myself. The Stinger was on one of the "spinners" and they had a lower model on the floor. Overall it's a good looking car, but it's too big for my liking. It's very long. I thought the new Accords looked pretty good actually. A lot of people milling around them. They will sell plenty of them for sure.
The Sportback is really great looking in person— low, sleek, modern. Not much difference at all between the A4 and A5 interiors/tech. For all intents and purposes same car, different body styles.
#172
Honda is not the only car company using the transmission. That said I think a transmission built for FWD transverse engines is not really a candidate for tooling down the Autobahn at 120MPH. Also having all those gears does not equate to a high top speed. IIRC 4 of the gears are overdrives & more then likely the car is no faster in the higher OD gears then the lower ones. Each time you shift up it takes more power just to hold your speed because you are into a negative gear advantage after the 1:1 ratio.
Some old cars didn't inspire confidence, to say the least, when driving at 80, 100, 120 MPH, but the TLX doesn't even feel like you're pushing it to go 100. However, I can't say if it would feel comfortable regularly cruising at 120MPH or not, as I don't really want to push my luck in terms of other drivers causing problems, or police giving me tickets, so I won't be testing my car's high speed performance limits, not even close...
After watching some reviews of the BMW M2, I have to wonder, why even consider Audi anymore? I think I may have to test drive one, maybe next summer.
#173
Totally agree. The other difference is interior space as obviously the SB is larger. I do like the frameless glass on the doors also. They carry that over also from the A5 Coupe.
#174
I test drove an A5 SB (non S-line), feels very similar to my A4. Didn't order one since was brand new, little discount and long wait. Family wise, extremely interesting since you have a massive amount of room. I also loved the frameless windows!
#175
So I actually looked and test drove the TLX A-Spec but I was disappointed, so I ended up buying a A5 SB and I have to say that I have had no issues so far. Look Audi's reliability has gotten better.
The following 3 users liked this post by comptr:
#176
That is true since the A4/A5 have the exact same interiors, the only difference is the body style. Oh, now they are willing to discount the SB's, I got around 12% off the msrp.
The following 2 users liked this post by comptr:
FLYGUY31 (01-29-2018),
pyrodan007 (01-30-2018)
#177
I got a prestige trim level with the S-line package, 19" S-line wheels, Cold weather package, Drivers Assistance Package, Ventilated Seats, and Audi beam rings. The car was on the dealer lot and they ordered it, so it had all most all of the options.
#180
Well done, good deal. Compared to my TLX, I do miss the remote starter and heated steering wheel (flat bottom). But overall, it's a great daily driver.
#181
Sounds really nice..post a pic if you can. That's basically the exact model I'd want.
#182
#183
Azine Jabroni
#184
Audi revamps as sales stumble
Stung by declining sales of its iconic A4 sedan and the public relations black eye of another diesel scandal, Audi is racing to repair its marketing image by rolling out new models, including what is hoped to be the first electric German luxury SUV.
According to industry statistics, VW’s luxury car unit sold 200,000 fewer autos than BMW in 2017 and 400,000 fewer than Mercedes Benz. Chief among the problems: dealers complain that they are losing money on the A4 and sales in Germany are down by 3 percent and would have been worse had it not been for deep discounting.
#185
You'll Never Walk Alone
https://www.theguardian.com/business...ns-and-monkeys
#186
Azine Jabroni
https://www.forbes.com/sites/johnmcc.../#6e4524ba6dd2
the A4 is killing it right now
#187
The picture and description in this article indicate this was actually written a long time ago. This is about the B8 A4.
I am seeing more and more A5 Sportbacks. Such a nice looking car. Photos never do it justice.
#189
Azine Jabroni
lol. How many Acuras are selling in Japan right now?
kurtatx (01-31-2018)
#191
Audi sales +9.9% in January. Lead by A4 +17%. And A5 due to new SB model.
#194
Please tell me you're joking. Audi A4 sales numbers are a joke. Way behind C class and the 3 series for the last couple of years. This thing is a sales flop. Just because you bought one does not make it a success. Sales numbers have only been around 2k+ per month, where C class consistently sells at 6k+ per month.
#195
#196
Azine Jabroni
Also
The following 2 users liked this post by kurtatx:
pyrodan007 (02-01-2018),
rockstar143 (02-02-2018)
#198
Azine Jabroni
I would argue both are selling well, but the A4 is a major factor as to why Audi is continuing to see huge sales numbers.
You can't say "Well the 3 series is selling more so the A4 is a flop". BMW sells more. They always have. Car marques can only hope to improve based on their own standards. It's like saying Subaru is a flop because they don't outsell Toyota. It's a logical fallacy.
That's why the TLX is a mega disappointment and the A4 is a success. Acura sedans were once great and are now trash and sales for Acura sedans are awful. Audi has always been a smaller player and are continuing to improve.
BEAR-AvHistory (02-01-2018)
#200
My understanding from some of the members here is that Audi doesn't have the same aggressive lease deals like BMW.
Not sure if there's much point of comparing the TLX...when it's one of the oldest cars in the segment and it wasn't exactly groundbreaking when new....based on the new RDX, I think the 2nd gen TLX would be more interesting.
