Highest Mileage TLX?
Just seeing how many miles everyone has on their TLXs. Mine just passed 60k trouble free miles - minus the crappy Acura batteries. Any other higher mileage TLXs? Run into any issues?
2016 TLX Advance - 25k miles.
2015 Advance - 45,440mi.
Still have the original battery and no other issues. |
16 V6 PAWS - 27k |
19 A-spec, 1,900 miles :vtec:
Was expecting to see some higher mileage! Maybe I drive too much!
Recently turned in my 2015 TLX 4 cylinder lease with 74,500 miles. It was very reliable. Just regular oil changes and new tires. Loving the 2018 refreshed model so far. |
2018: 19,000mi. |
2015 - 80,000mi.
I don't drive as much in this car as I used to in my 3G TL, but I've managed to get about 83,000 miles far-from-trouble-free miles in my 2015.
2016 42,000 miles. One new battery, new front motor mount, new lkas sensor, and waiting to see if they going to fix my chirping noise lol. Other than that, car run great!
My 2015 2.4Tech just passed the big 100,000 mark yesterday. Currently sits at 100,048
2015 - 19,000 miles.
Working from home makes fora short commute... |
2015 V6 Tech FWD - 36,000 miles
2018 TLX A-Spec V6 - 3700 miles
2015 TLX base 4 cyl. 75,500 miles. Had battery replaced under warranty and new set of tires not too long ago. Very reliable
Originally Posted by frack
(Post 16287192)
2015 tlx v6 tech - 79K miles
2018 TLX A Spec 20,000miles
I just turned 75,000 miles on my 2016 TLX. When should I change/flush the tranny fluid?
2016 SHAWD Advance - 53K miles. Routine maintenance mostly. Problems - 1 door lock actuator replaced under warranty and intermittent HVAC fan failure, but always works when in for service.
Originally Posted by oconm77
(Post 16311040)
Just traded in my 2018 TLX A-spec today with 11,000 km (6,800 miles). Going to miss that San Marino Red. |
2018 TLX with roughly 40K KM's which i think is almost 25k Miles...
Originally Posted by SebringSilver
(Post 16318823)
I heard about front headlights LED failing, meaning about 1000$ each side.
Anybody with a long term TLX has this issue? |
I have had my car TLX since November 2014. The LEDs didn't fail, but the clear coat started to fail on both in the corner of the lights by the turn signals. Had both headlights replaced under warranty. The cost is $1250 each, and that does not include labor to install them. Luckily the warranty covered it 100%
2015 V6 Advanced 36,000
my 2015 tlx 4 cyl base has about 79k on it. No problems just regular oil changes, tires, and changed transmission fluid at 50k miles just for preventive maintenance. Starting to like the new look of TLX's, however two 3G TL's sitting in the garage keep the mileage down.
(Post 16311040)
2015 v6 tech 27k miles
(Post 16311040)
Originally Posted by deanoatkinson
(Post 16344307)
should have done it twice already every 30k
BTW, if anyone's got the 9-speed, and aren't doing the transmission fluid change on your own, the dealership is charging $300-$400 for the change (well, the 2 that I dealt with, anyway). The ZF/Acura 9sp tranny ... the gift that keeps on giving. :D |
