Hi, I got wheel alignment done along with new set of tiers at the local discount tires store and they gave me the following report. When asked about the rear toe being in red they said that is the max we can do. Any suggestions what should be done here? should I take it to the deanship to do the alignment again? also what can be the problem driving with this alignment, I don't feel any difference in handling or car pulling on one side.
When asked about the rear toe being in red they said that is the max we can do. Any suggestions what should be done here? should I take it to the deanship to do the alignment again? also what can be the problem driving with this alignment...
Bent arm maybe. The rear camber isn't in the middle either. That will affect toe as well. You'll wear the tire unevenly.
Suggest an aftermarket adjustable toe arm, then re-align.
