AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   5G TLX (2015-2020) (https://acurazine.com/forums/5g-tlx-2015-2020-415/)
-   -   2020 Acura TLX - high pitching noise under idle (https://acurazine.com/forums/5g-tlx-2015-2020-415/2020-acura-tlx-high-pitching-noise-under-idle-1010319/)
Music_listener9973 May 24, 2025 08:42 PM
Hey everyone,
I was at my buddy’s doing an oil change. Afterward with the hood still up, we decided to turn it on to check for leaks.
that’s when I started hearing a high pitched, ringing noise coming from the engine area. Not sure how long it’s been there. it seems to go away when I give it a throttle - mainly during idling.
video: https://youtube.com/shorts/vDhMwVAoucw
2020 Acura TLX
47k miles
thank you
NDNV May 26, 2025 08:25 AM
Used 0W20 synthetic and filled between the 2 dots on dipstick? Used the correct oil filter? Your video doesn't appear to show valve cover gasket leaking onto the serpentine belt tensioner causing a noise.
Music_listener9973 May 26, 2025 08:51 AM
This is an image from a cold-engine.
https://cimg4.ibsrv.net/gimg/acurazi...805a743361.png
NDNV May 26, 2025 02:25 PM
Level should be between the 2 holes on the dipstick - check after three minutes after shutoff. I have same engine and don't have that noise. Check pulleys associated with serpentine belt, alternator, water pump and tensioner.
© 2026 MH Sub I, LLC dba Internet Brands
