2018 Acura TLX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2018 Acura TLX Technical Service Bulletins:
TSB 17-022 - 2018 TLX: TQI and New Model Service Information
Applies To: 2018 TLX - 4-Cylinder 2WD: P-AWS, 8-Speed DCT - Base, Technology
2018 TLX - 6-Cylinder 2WD: P-AWS, 9-Speed A/T - Base, Technology, A-Spec, Advance
2018 TLX - 6-Cylinder AWD: SH-AWD, 9-Speed A/T, Auto Idle Stop - Technology, A-Spec, Advance
http://www.urvi.net/forumfiles/SB/B17-022.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-022.PDF
TSB 17-023 - 2018 TLX: TQI of the Navigation System
Applies To: 2018 TLX - All with Navigation
http://www.urvi.net/forumfiles/SB/B17-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-023.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2015-18 TLX - ALL with V6 - ALL
2019 TLX - 2WD with V6 - From VIN 19UUB2...KA000001 thru 19UUB2...KA007635
2019 TLX - AWD with V6 - From VIN 19UUB3...KA000001 thru 19UUB3...KA005453
http://www.urvi.net/forumfiles/SB/B14-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2015-18 TLX - ALL with 9-speed A/T - ALL
2019 TLX AWD - 9-speed A/T - From VIN 19UUB3F..KA000002 thru19UUB3F..KA002947
2019 TLX 2WD - 9-speed A/T - From VIN 19UUB2F..KA000001 thru 19UUB2F..KA003475
http://www.urvi.net/forumfiles/SB/B15-039.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2015-17 TLX - V6 Only - ALL
2018 TLX - 2WD (V6 Only) - From VIN 19UUB2...JA000001 - 19UUB2...JA003458
2018 TLX - SH-AWD - From VIN 19UUB3...JA000001 - 19UUB3...JA001898
http://www.urvi.net/forumfiles/SB/B17-034.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-034.PDF
TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment
Applies To: 2015-18 TLX - ALL with 10-way driver's power seat; ALL with 8-way passenger's power seat - ALL
http://www.urvi.net/forumfiles/SB/B18-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-014.PDF
TSB 18-060 - Audio Unit Restarts On Its Own or CarPlay Does Not Work after iPhone Update
Applies To: 2018-19 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-060.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-060.PDF
TSB 19-003 - MIL Comes On with DTC P0716
Applies To: 2015 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...FA021489 and later
2015 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...FA007728 and later
2016-17 TLX - V6 with 9-Speed A/T - ALL
2018 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...JA000001 thru 19UUB2...JA011767
2018 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...JA000001 thru 19UUB3...JA005470
http://www.urvi.net/forumfiles/SB/B19-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-003.PDF
TSB 19-005 - Multiple Indicators On and Option Fuse (E21 or B7) Blown
Applies To: 2018-19 TLX - V6 - ALL
http://www.urvi.net/forumfiles/SB/B19-005.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-005.PDF
TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump
Applies To: 2015-19 TLX V6 - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-011.PDF
TSB 19-012 - Knocking or Clicking From Engine During Cold Startup
Applies To: 2015-18 TLX - L4 - ALL
http://www.urvi.net/forumfiles/SB/B19-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-012.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2015-19 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-017.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2015-20 TLX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-013 - Navigation Display Distorts After 1 or More Hours of Driving
Applies To: 2018-20 TLX - Tech, Advance, Tech A-Spec - ALL
http://www.urvi.net/forumfiles/SB/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-013.PDF
http://techinfo.honda.com/rjanisis/p...enu/B14162.PDF (Link works, but is wrong)
TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration
Applies To: 2015 TLX - 2WD V6 9-Speed A/T - Transmission serial number above Q5J...60408
2015 TLX - AWD V6 9-Speed A/T - Transmission serial number above Q5L...25932
2016-20 TLX - 2WD V6 9-Speed A/T - ALL
2016-20 TLX - AWD V6 9-Speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B20-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF
TSB 22-008 - Product Update: 2015–20 TLX PGM-FI Idle Stop Software Update
Applies To: 2015-20 TLX - V6 SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-008.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-008.PDF
TSB 22-009 - Warranty Extension: Engine Does Not Auto Restart After Entering Auto Idle Stop
Applies To: 2015-20 TLX - V6 (SH-AWD) - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B22-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B22-009.PDF
TSB 23-009 - Engine Does Not Crank
Applies To: 2015-20 TLX - V6 - ALL
http://www.urvi.net/forumfiles/SB/B23-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-009.PDF
TSB 23-035 - MIL Comes on with DTC P0441
Applies To: 2018-2020 TLX (V6 Only) - ALL - ALL
http://www.urvi.net/forumfiles/SB/B23-035.PDF
http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF
TSB 24-002 - Safety Recall: 2015–20 TLX Connecting Rod Bearing
Applies To: 2015-20 TLX - V6 Only - ALL
http://www.urvi.net/forumfiles/SB/B24-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-002.PDF
TSB 24-007 - Safety Recall: 2015–20 TLX (Without SH-AWD) Fuel Pump Motor
Applies To: 2015-20 TLX (Without SH-AWD) - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-007.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-007.PDF
TSB 24-011 - Safety Recall: 2015–20 TLX SH-AWD Fuel Pump Motor
Applies To: 2015-20 TLX SH-AWD - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-011.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-011.PDF
The following 7 users liked this post by EE4Life:
natkhat (02-13-2019),
ogiewon (10-14-2017),
Speed_Racer (06-08-2017),
technocrat (09-21-2018),
Temp_A-Spec (09-04-2017),
and 2 others liked this post.
