2015 TLX TPMS Compatible with 2018 TLX?
Old 08-20-2018, 01:31 PM
edmua6's Avatar
Has anyone tried using a set of wheels from 2015 Acura TLX to a 2018 Acura TLX. I am thinking of buying a used set for the winter season.
Old 08-20-2018, 01:59 PM
xc1097's Avatar
nope, they are not compatible.
different part number as well & TPMS module won't recognize them when you put the wheels on the car.
Old 08-20-2018, 03:08 PM
edmua6's Avatar
Thank you for the response. Have you tried it yourself? I am aware they are different part numbers but the dealer told me it may work.
Old 08-20-2018, 05:58 PM
TSXV6Guy's Avatar
The 2018 operates at a different frequency so it will not work on the 2015.
Old 08-21-2018, 02:50 PM
2018 TLX Aspec
MattViperTLX's Avatar
what happens if you dont' put TPMS on winter tires? i'm planning for wheels/tires too for the winter and want to save money if possible not to install tpms
Old 08-21-2018, 05:30 PM
TSXV6Guy's Avatar
The TPMS light will stay on and it will be impossible to disable traction control in case you need to.
Old 08-27-2018, 02:43 PM
18TLXAspec's Avatar
I'll just confirm the 2015 sensors will not work with 2018. I bought a set of snow tires/rims that had those sensors and there's now way to get them to paired with the vehicle. The TPMS warning will pop-up every time you start the car. I can't confirm what TSXV6Guy says about the traction control b/c I didn't test disabling when I had them on the vehicle. I plan on replacing the 2015 sensors w/ 2018 sensors eventually, probably when I need a new set of snow tires installed.
Old 09-01-2018, 11:11 PM
mapleloaf's Avatar
What about 2016 sensors in a 2018?
Old 10-17-2018, 06:14 AM
smoore's Avatar
I think the change of sensors was made in 2018. I have 2015 sensors on the snows for my 2017 and they work fine.
anthuny85
5G TLX Photograph Gallery
28
03-14-2021 09:49 PM
ablb454
14
04-12-2019 11:13 AM
princeo5
02-02-2019 07:50 PM
ostrich
5G TLX Problems & Fixes
11-07-2017 12:53 AM
Sloppy305
05-15-2017 06:20 PM
Quick Reply: 2015 TLX TPMS Compatible with 2018 TLX?
