2015 tlx acceleration problem
My car is a v6 awd with 144K miles. I was driving and all of the lights on the dashboard lit up like a Christmas tree and the car didn’t want to accelerate until I floored it then it slam the lower gear.cruising at light throttle is when you can feel like the car is stuck at 20 even when flooring it.No check engine light or codes. I’ve read that it could be the battery so I changed the battery and still the same symptoms? My question for you guys is there a pedal position sensor on the tlx? Has anyone experience this? Sorry if this was discussed before. I did search but only found third generation tl discussions.
Yes there is a pedal positioning sensor. It is located right underneath the pedal pad.
Better get that checked out soon. Sounds like you went into limp mode - it was that serious. A bad battery shouldn't cause a slam-in-lower gear situation. All recalls performed and what is the transmission service history?
There’s a recall on the transmission?
TSB 14-050 - Safety Recall: Transmission Does Not Engage Park
Applies To: 2015 TLX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B14-050.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-050.PDF TSB 15-034 - Product Update: Vehicle Shifts into Neutral and MIL Comes On with DTC P0657 Applies To: 2015 TLX - With 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B15-034.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-034.PDF TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T) Applies To: 2015-18 TLX - ALL with 9-speed A/T - ALL 2019 TLX AWD - 9-speed A/T - From VIN 19UUB3F..KA000002 thru19UUB3F..KA002947 2019 TLX 2WD - 9-speed A/T - From VIN 19UUB2F..KA000001 thru 19UUB2F..KA003475 http://www.urvi.net/forumfiles/SB/B15-039.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-039.PDF TSB 15-040 - Firm 2nd to 3rd Gear Upshifts Under Certain Driving Conditions Applies To: 2015 TLX - V6 2WD - From VIN 19UUB2...FA000001 to 19UUB2...FA021489 2015 TLX - V6 SH-AWD - From VIN 19UUB3...FA000001 to 19UUB3...FA007728 http://www.urvi.net/forumfiles/SB/B15-040.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-040.PDF TSB 15-041 - Multiple Indicator Lights Come On, Stuck in 4th Gear, and Temporary DTC P0714 is Set Applies To: 2015 TLX - V6 with 9-speed A/T - ALL http://www.urvi.net/forumfiles/SB/B15-041.PDF http://techinfo.honda.com/rjanisis/p...nu/B15-041.PDF TSB 16-075 - Safety Recall: 2015 TLX V6 A/T Sensor Cluster Crimp Failure Applies To: 2015 TLX - V6 with A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B16-075.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-075.PDF TSB 17-011 - Product Update: TLX 9-Speed Transmission Warmer Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B17-011.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-011.PDF TSB 17-012 - Product Update: TLX 9-Speed Transmission Warmer (Transmission Previously Replaced for Transmission Warmer Leaking) Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B17-012.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-012.PDF TSB 17-027 - Warranty Extension: TLX Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B17-027.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-027.PDF TSB 19-003 - MIL Comes On with DTC P0716 Applies To: 2015 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...FA021489 and later 2015 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...FA007728 and later 2016-17 TLX - V6 with 9-Speed A/T - ALL 2018 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...JA000001 thru 19UUB2...JA011767 2018 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...JA000001 thru 19UUB3...JA005470 http://www.urvi.net/forumfiles/SB/B19-003.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-003.PDF TSB 20-015 - 9-Speed A/T Hard Upshift with Steady Acceleration Applies To: 2015 TLX - 2WD V6 9-Speed A/T - Transmission serial number above Q5J...60408 2015 TLX - AWD V6 9-Speed A/T - Transmission serial number above Q5L...25932 2016-20 TLX - 2WD V6 9-Speed A/T - ALL 2016-20 TLX - AWD V6 9-Speed A/T - ALL http://www.urvi.net/forumfiles/SB/B20-015.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-015.PDF There are also fuel pump and rod bearing recalls on the 2015 as well. First year model grief... |
Quick update: so the symptoms disappeared after I switched over the battery (knock on wood). Thanks y’all for your advice.
| All times are GMT -5. The time now is 11:40 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
