2015 Acura TLX Technical Service Bulletins
#121
Adding new TSB. Mods will need to merge it with the original post.
TSB 15-041 - Multiple Indicator Lights Come On, Stuck in 4th Gear, and Temporary DTC P0714 is Set
The following 2 users liked this post by EE4Life:
9SpeedTran (08-21-2015),
tlxsteve (08-22-2015)
#125
UB1 = TLX 2WD / K24W7
UB2 = TLX 2WD / J35Y6
UB3 = TLX SH-AWD / J35Y6
2015 Acura Passenger Vehicle VIN Information
http://www.urvi.net/forumfiles/SB/BXX51781.PDF
http://techinfo.honda.com/rjanisis/p...u/BXX51781.PDF
The following 3 users liked this post by EE4Life:
#126
Based upon the link EE4Life provided, it looks like the VINs may be reversed on TSB 040. I'm at the dealership now getting an oil change and decided not to put the service guy at odds with what the TSB says. I'll wait for hopefully a correction or something to make certain.
#127
I got both TSB 40 and 41 applied as part of a B16 service yesterday, and initial results are that the 2-3 shift, and all others, are smooth as buttah. I hope it stays that way...But it looks like they may have actually fixed this. I had noticed the shift was particularly rough when I was gently revving the engine up to the shift point, and so that was what I tried first, and it was no different than the others. I also tried it with a hard punch from start, which had been very smooth before the fix, and it still was. So, fingers crossed. :-)
#128
What happens in stop and go traffic? Have you tried soft acceleration also? My transmission is fully back to shifting terribly, after the 15-040 update. I did not get 041 done, as this seems to be only if the transmission locks in a gear.
#129
The following 4 users liked this post by EE4Life:
#130
Seems fine but I don't spend that much time in stop-and-go traffic, thankfully.
#131
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
tlxsteve (08-29-2015)
#134
#135
I'm going in for my A1 service soon at 5k miles. I've skimmed through this thread and seems the only TSB that applies to mine are the ones with VIN "ALL" (SH-AWD V6). Should I still verify with the service department about the other TSB that don't call out my VIN? And will they provide me a list of the service done to the car (other than oil change, tire rotation, etc.)? Also, what other things should I look out for before taking it in so I can address it? (Except for the hard shift, gear hesitation, and random rattling sounds).
My dealership seems sketchy with their service so want to make sure they're doing their jobs!
Thanks.
Thanks.
#136
^ My dealership wasn't exactly on top of the most recent SB's. What I would do is print off the ones from this thread you have questions about and just bring them with you. I did that, and what my service rep did was double-check the VINs. If your VIN is outside the range they won't apply the bulletin. But if you have the ones in-hand for them to check, you'll force them to make the call. I'm not convinced they would have gone and looked on their own. They should also confirm in your service receipt what was and was not applied.
#137
Thanks.
#138
TSB 15-042 - Fluttering Noise From Behind Dashboard
tlxsteve (09-26-2015)
#139
TSB 15-034 Broke my Auto Engine Idle Stop
During the B16 service the technician installed this software.
I noticed the Auto Engine Idle Stop wasn't working and got a warning that it was unavailable.
I have an appointment tomorrow to get it fixed.
I did notice in the TSB that if you get a warning while installing that you need to turn off the Idle Stop function.
#140
TSB 15-050 - Multiple Indicators are On with DTC U129D
flybyglass (05-23-2016),
tlxsteve (10-29-2015)
#141
This one actually happened to me a few months ago and they replaced the actuators just as stated. Haven't seen a problem since. I don't know if you guys will be able to get them to replace it until something goes wrong, though. It is not a cheap fix from what I was told. I could've sworn they told me it was a couple thousand or something to replace if it wasn't under warranty (assuming this is the same thing they did to my car which it seems like).
#142
TSB 15-042 was revised today. Mods to revise the original post with the information below.
#143
TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane
#144
Thanks for your good work as always.
#145
PRO:
Safety of having a spare tire in case of emergency
CON:
Extra weight and space of extra tire and accessories
I can say it is extremely handy having a compact air pump. (No more having to goto the gas station.) In my experience, I've needed an air pump far more times that I've had to change a flat that couldn't be patched.
NOTE: Keep in mind that if you have to use the tire sealant in the event of a flat, it may damage\ruin the TPMS sensor.
#146
^^^ I went through the same rationale and decided against the spare tire since I can't remember the last time I used one. A lady swerved into my lane recently and I drove into a curb at around 50 mph. The tire blew out its side and the rim bent. Had to call "Acura" for a tow because the goop in the trunk wasn't going to fix that. Took about 2 hours to get towed to an Acura dealership. It's like the old saying "the minute you don't think you'll need it, you'll need it". Sadness.
#147
#148
#149
#150
is the affected vin # range FA000001 thru 19UUB3 or 19UUB3 thru FA000001?
i have a 19UUB1 just trying to see if i'm in the affected range
thanks
#151
EE4Life, I really appreciate your TSB posts!
My VIN was in the range for the timing belt chirps. I brought my car in for an oil change, and my dealer told me there were no recalls for my car. I had printed out the timing belt SB and asked them to check it, and my car was okay.
I guess recalls are different from Service Bulletins, but don't you think the dealer should have told me about this SB rather than me having to tell them? I'm glad I printed this out!
#152
...that was his explanation to me.
#153
I had that same question at my first A1 service. The service manager says they won't do it unless I ask them about it and have issues with it. Not all VIN are affected even though the TSB called out the ranges. However, by mentioning it to them or printing out the TSB for them, they will look at it and service as necessary.
But the SB says:
Start the engine, let it warm up, and listen for a chirp.
NOTE: It can take up to 30 minutes for the engine to become hot enough to hear a chirp.
By that time I'd be driving along to wherever I was headed, and I doubt that I'd hear a chirp if I had one!
#154
The affected ranges are FA000001 to FA025139 on the 2WD V6 TLX and FA000001 to FA010310 on the AWD V6 TLX.
#156
#157
TSB 16-009 - Vibration Felt in Floor at Highway Speed
#158
TSB 08-031 - Chirp From the Timing Belt Area
http://www.urvi.net/forumfiles/SB/B08-031.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/B08-031.PDF
#159
