2015 Acura TLX Technical Service Bulletins
Old Sep 30, 2014 | 06:50 PM
  #41
wlkeel's Avatar
Here's the procedure for one of the Mercedes (copied from one of their forums):
"According to the manual for the 2013 GLK 250 BlueTEC there is a requirement to set the car in permanent neutral when going through a tow car wash. They state to remove the Keyless Go if necessary and switch the car on using the Smartkey. Then place it into neutral and make sure the parking brake is off. Then switch off the ignition but LEAVE THE SMARTKEY IN THE IGNITION SLOT.
Is the car wash really going to know this unless you are standing over them?"
It has a push button type transmission.
O.K., I'm through
Old Oct 30, 2014 | 04:06 PM
  #42
EE4Life's Avatar
Forum Contributor
Adding new TSB. Mods will need to merge it with the original post.
TSB 14-037 - Client Satisfaction Improvement Campaign: Update for 2015 MDX and TLX ODMD (Vehicles with Navigation)
Old Oct 30, 2014 | 04:57 PM
  #43
tlxsteve's Avatar
TSB 14-036 - Noncompliance Recall: TLX Certification Label
FYI: Seems I cannot access any of the second links.
I get this message...
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
Is it just me? It could be.
Very neat information on what I can access. Thanks.
Old Oct 30, 2014 | 06:40 PM
  #44
rickd's Avatar
Thanks EE4Life. I was just complaining about the voice address input for my MDX to one of the salesmen. I'm glad it will be addressed with this update.
Old Oct 30, 2014 | 07:37 PM
  #45
Gregg's Avatar
Thanks much for the link. I just found out about it on owners.acura.com and crossposted to the Audio/BT/Nav subforum.
Old Oct 31, 2014 | 10:37 AM
  #46
tlxsteve's Avatar
Looking forward to more TSBs now that One-Packs are finished.
Old Nov 1, 2014 | 12:43 PM
  #47
MedX172's Avatar
Originally Posted by Stew4HD
^ It's a valid question and concern. IMO, technology can go too far trying to be "smart". Maybe Acura will address this, especially if the unthinkable happens and a TLX messed up a car wash and/or the car id damaged because of it.
I agree completely. The procedure is a bit to complicated and the duration is to short; IMHO 20 minutes would have been better. If I did elected to use the local car detail place, I'd likely have to get the manager to tell them in Spanish so all the details got communicated. They're very friendly guys but direct communication can be challenging for some of them.
My thought for the Winter when I'm to busy to do it myself, is to just pony up and get my detailer to do it or pay the extra $$ for the hand wash (which also has the possibility to go wrong) rather than send it through the touch-free automation they use.
Old Nov 6, 2014 | 12:05 PM
  #48
tlxsteve's Avatar
Man I wish this will become a sticky thread.
Old Dec 4, 2014 | 10:14 PM
  #49
EE4Life's Avatar
Forum Contributor
TSB 14-050 - Safety Recall: Transmission Does Not Engage Park
Old Dec 4, 2014 | 10:37 PM
  #50
Rocketsfan's Avatar
^^ Hmm... can anyone get the links to load? I'm trying to see if there's a block of VIN's affected.
Old Dec 4, 2014 | 10:55 PM
  #51
ostrich's Avatar
No, unfortunately, they don't work for me either....
Old Dec 4, 2014 | 11:02 PM
  #52
EE4Life's Avatar
Forum Contributor
The urvi.net links are currently unavailable since the server is down. Things should be working again by Monday.
For now, use the Honda links via the methods posted in the forums.
Sorry for the inconvenience.
Old Dec 5, 2014 | 05:51 AM
  #53
smoore's Avatar
The simplest way to prevent the car from automatically shifting from N to P when you exit the vehicle is to do up the seatbelt behind you. Tell the attendant not to undo the seatbelt. The car will stay in N.
Old Dec 5, 2014 | 09:56 AM
  #54
tlxsteve's Avatar
Found this on Honda.com/recalls:
NHTSA RECALL NUMBER: AWAITING#
MFR CAMPAIGN ID: JM8
RECALL DATE: 12/03/2014
RECALL STATUS: Recall INCOMPLETE. Remedy not yet available.
SUMMARY:
AMERICAN HONDA MOTOR CO., INC. (HONDA) IS RECALLING CERTAIN MODEL YEAR 2015 ACURA TLX V6 VEHICLES. DURING MANUFACTURING OF THE 9 SPEED AUTOMATIC TRANSMISSION, IT IS POSSIBLE THAT CONTAMINATION MAY GET INTO THE PARKING PAWL OR THE PARK ROD MAY BECOME DISLODGED OR BROKEN, BOTH OF WHICH CAN PREVENT THE TRANSMISSION FROM SHIFTING INTO THE PARK POSITION.
SAFETY RISK:
ALTHOUGH THE SHIFT INDICATOR WILL DISPLAY "PARK", THE PARK LOCK MAY NOT ENGAGE, ALLOWING THE VEHICLE TO ROLL AWAY AND INCREASING THE RISK OF A CRASH.
REMEDY:
HONDA WILL NOTIFY OWNERS, AND DEALERS WILL INSPECT AND, IF NECESSARY, REPLACE THE TRANSMISSION, FREE OF CHARGE. THE LETTER WILL ALSO INFORM THEM ALWAYS TO ENGAGE THE MANUAL PARKING BRAKE AS A PRECAUTION UNTIL THE INSPECTION CAN BE COMPLETED. BECAUSE THE NEW VEHICLE WARRANTY ON ALL AFFECTED VEHICLES WOULD HAVE PROVIDED A FREE REPAIR FOR THE PROBLEM ADDRESSED BY THIS RECALL, WITHOUT ANY PAYMENT BY THE OWNER, REIMBURSEMENT FOR PRE-NOTIFICATION REPAIRS WILL NOT BE OFFERED. NOTIFICATION TO CUSTOMERS ABOUT THIS RECALL IS EXPECTED TO BEGIN ON JANUARY 6, 2015. OWNERS MAY CONTACT ACURA CLIENT RELATIONS AT 1-800-382-2238, OPTION 4. HONDA'S CAMPAIGN NUMBER FOR THIS RECALL IS JM8.
Old Dec 5, 2014 | 10:55 AM
  #55
CheeseyPoofs McNut's Avatar
SUMMARY:
SAFETY RISK:
REMEDY:
Yikes - this doesn't bode well for the downward trending CR reliability score
Props to AHMC for moving quickly on this recall.
Old Dec 5, 2014 | 11:05 AM
  #56
BEAR-AvHistory's Avatar
The "feature" is a PIA. Seems pretty common with the ZF style transmissions.
Old Dec 5, 2014 | 05:10 PM
  #57
EE4Life's Avatar
Forum Contributor
The server is back up and the urvi.net links are now available.
Old Dec 7, 2014 | 10:15 AM
  #58
9SpeedTran's Avatar
How do you get to the iN VIN thing to see which VINs are affected?
Old Dec 7, 2014 | 10:21 AM
  #59
EE4Life's Avatar
Forum Contributor
You need to contact your dealer and provide them with your VIN and they will see if your TLX is affected or not.
Old Dec 7, 2014 | 11:50 PM
  #60
Rocket_man's Avatar
Summer is Coming
You can try this too...
American Honda Motor Co., Inc. Divisions
Old Dec 8, 2014 | 06:28 AM
  #61
narnia's Avatar
Team SSM Queen
Has anyone tried this? Sounds like a very easy fix if it works!
Old Dec 8, 2014 | 06:36 AM
  #62
Stew4HD's Avatar
I think you can test it out pretty easy.. just make sure you are on flat ground and/or chock the tires. I'd try test it out for you but... soon.
I am interested in knowing that as well
Old Dec 8, 2014 | 12:52 PM
  #63
narnia's Avatar
Team SSM Queen
This is one of those rare days when I'm not in my car. I'll try it tomorrow and report back!
Old Dec 9, 2014 | 11:06 AM
  #64
CanTex's Avatar
Not a problem for my 2.4, but I asked the car wash supervisor about it and he said, "Huh?" No clue. The majority of V6 owners aren't enthusiasts and will have no clue about car wash mode. Acura needs to make this go away.
Where I go, the car is in neutral with the engine running when it goes through, so all the guy at the end of the line has to do is put it in gear and drive to the wipe-down area.
Old Dec 9, 2014 | 05:57 PM
  #65
Quandry's Avatar
^^ Acura is not going to do anything about for existing cars. Maybe there will be a refinement at MMC.
Old Dec 9, 2014 | 08:00 PM
  #66
Rocketsfan's Avatar
FYI : There's (should be) a yellow laminated card in the car when you take delivery talking about carwash mode.
Old Dec 10, 2014 | 01:34 AM
  #67
4WDrift's Avatar
Can a mod sticky this one too?
  #68
Davinci547Acura's Avatar
Placard was sitting on console beside salesperson when I took delivery. Salespersons job to bring to attention of new owner, but we all know that doesn't always happen. Complicated and dangerous procedure in real world reality, IMHO.
I also agree corporate should do away with this "feature". After a few automated wash mishaps and damaged car lawsuits, Acura might take notice.
Not worrying about it personally because I hand wash my cars but know most people don't.
Old Dec 10, 2014 | 07:11 AM
  #69
miner's Avatar
This was one of the first items mentioned by my salesperson when I took delivery of the car. Another reason owners need to spend time with the manual after purchasing the car.
Old Dec 10, 2014 | 08:47 AM
  #70
Quandry's Avatar
Originally Posted by Davinci547Acura
.... Complicated and dangerous procedure in real world reality, IMHO.
Complicated, yes (but not after doing it a few times). Dangerous, I don't think so. It would take a lot of "successful" lawsuits to make a difference, and I think this is unlikely.
It does not affect me either because I do not use that type of car wash. Maybe it is time for a poll on what of method car wash do people use. In my area it would less than 5% that use the driverless kind.
  #71
CanTex's Avatar
I am considered a "techie" by friends and relatives, BUT, even with the 2.4 Tech I was overwhelmed by information and still have to dig out the PDF version of the manual or e-mail the service guy for advice. If you're laying out that kind of money for a V6, lease or purchase, you've probably achieved some reasonable status in life. The majority of folks at that level would likely say, "Yeah, whatever." and basically ignore it until the car gets jammed in the car wash. I hope I'm wrong.
Old Dec 10, 2014 | 08:50 AM
  #72
CanTex's Avatar
For the poll: "My" local car wash, driverless, does a great job, including vacuum, hand-wipe, interior wipe-down, inside window wipe-down, and tires for $10.99 plus cash tip. This is in the Dallas Fort Worth area. To me, it's worth it.
The dealer is 20 miles away and they don't do much on the interior.
Old Dec 10, 2014 | 06:36 PM
  #73
May be 5% because you're in Canada and not southern CA, AZ, NM, TX, GA, FL that have many driverless automated car washes. Dangerous yes, because most of these facilities hire minimum wage workers, many don't speak English fluently or at all and often only work at the facilities temporarily and new replacements are hired, so constantly changing personnel. Who will teach all these workers to operate a trick TLX procedure when that waiting line of hundreds of cars, all different need to get through that line to keep the $ money coming in?
I know of one automated, very busy car wash in Los Angeles County that is constantly stopping while cars are going through the line. Wait till a TLX breaks the 15 minute rule in that facility.
Let the hate begin........
Old Dec 10, 2014 | 07:30 PM
  #74
Quandry's Avatar
Mea culpa. I guess we tend to express our view based on personal experience, and this does not necessarily apply to everyone everywhere.
Old Dec 10, 2014 | 07:49 PM
  #75
ITdude's Avatar
I live in the DFW area and also use a driverless car wash, although I pay $15 and it is worth it to me also. I will wash it myself every now and then to really get my car detailed, but only when the outside temperature is comfortable!
Old Dec 11, 2014 | 08:19 AM
  #76
CanTex's Avatar
I just checked my last receipt: $11.99. Still a great deal. A couple of bucks tip and off I go. This is in the Mid-Cities.
My old '01 TL, which was pretty well trashed out by my son, was ready to go at 185K miles, so we took it to this car wash before going to CarMax for an appraisal. Like, whoa, who's car is this and why are we selling it? The car looked terrific inside and out, and $14 on a car wash got us more money on the trade, I'm sure. They tell me it was sold as-is, no further detailing, in less than two hours. We were happy at the price and our sales guy was happy for the quick sale.
Old Dec 17, 2014 | 07:29 PM
  #77
tlxsteve's Avatar
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Thanks for the info.
Not much detail to it, but it apparently affects all 2015 TLXs.
p.s. Unless the info is in the post I cannot access.
Old Dec 17, 2014 | 09:35 PM
  #78
accord1999's Avatar
From how I read it, it sounds to me that Honda is clarifying what it will and will not pay for if there is an issue with the TPMS sensor and not an actual widespread issue with the system itself.
Old Dec 18, 2014 | 07:29 AM
  #79
9SpeedTran's Avatar
BTW, I took the TLX to the car wash for the first time (we have a really good one with nice soft felt cleaners with very gently rotation, they do a great job) and explained the whole thing and showed them the card, and the team lead had all of the guys around explaining it to them. I was very impressed.
So the time comes to take it in and the guy drives it in, opens the door, and then apparently says screw it and gets back in the car and rides it through himself. When he got out of the car I thanked him and gave him a big hug and smile, and he gave me a huge smile back. That's the kind of folks you want to work with.
Old Dec 18, 2014 | 09:41 AM
  #80
a35tl's Avatar
Nice story.
