2015 Acura TLX Accessory Installation Instructions
Forum Contributor
Received 1,392 Likes
2015 Acura TLX Accessory Installation Instructions:
2015 Acura TLX Accessory Installation Times
http://www.urvi.net/forumfiles/SB/BFR51980.PDF
http://techinfo.honda.com/rjanisis/p...u/BFR51980.PDF
2015 Acura TLX 18 Inch Aluminum Wheel
http://www.urvi.net/forumfiles/SB/BII51427.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51427.PDF
2015 Acura TLX 19 Inch Aluminum Wheel
http://www.urvi.net/forumfiles/SB/BII51428.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51428.PDF
2015 Acura TLX All-Season Floor Mats
http://www.urvi.net/forumfiles/SB/BII51416.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51416.PDF
2015 Acura TLX Backup Sensors
http://www.urvi.net/forumfiles/SB/BII51426.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51426.PDF
2015 Acura TLX Body Side Moldings
http://www.urvi.net/forumfiles/SB/BII51449.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51449.PDF
2015 Acura TLX Cargo Dividers
http://www.urvi.net/forumfiles/SB/BII51419.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51419.PDF
2015 Acura TLX Cargo Hook
http://www.urvi.net/forumfiles/SB/BII51448.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51448.PDF
2015 Acura TLX Door Edge Film
http://www.urvi.net/forumfiles/SB/BII51417.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51417.PDF
2015 Acura TLX Fog Lights
http://www.urvi.net/forumfiles/SB/BII51425.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51425.PDF
2015 Acura TLX Front Under Spoilers (Revised 12/11/2018)
http://www.urvi.net/forumfiles/SB/BII51429.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51429.PDF
2015 Acura TLX Illuminated Door Sill Trims
http://www.urvi.net/forumfiles/SB/BII51410.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51410.PDF
2015 Acura TLX Lower Door Chrome Trim
http://www.urvi.net/forumfiles/SB/BII51657.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51657.PDF
2015 Acura TLX Rear Bumper Applique
http://www.urvi.net/forumfiles/SB/BII51418.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51418.PDF
2015 Acura TLX Rear Seat Covers
http://www.urvi.net/forumfiles/SB/BII51659.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51659.PDF
2015 Acura TLX Rear Splash Guards
http://www.urvi.net/forumfiles/SB/BII51413.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51413.PDF
2015 Acura TLX Rear Under Spoilers (Revised 12/11/2018)
http://www.urvi.net/forumfiles/SB/BII51430.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51430.PDF
2015 Acura TLX Side Under Spoilers
http://www.urvi.net/forumfiles/SB/BII51411.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51411.PDF
2015 Acura TLX Steering Wheel
http://www.urvi.net/forumfiles/SB/BII51457.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51457.PDF
2015-2017 Acura TLX Trunk Spoiler (08F10-TZ3-201)
http://www.urvi.net/forumfiles/SB/BII03788-02.PDF
http://techinfo.honda.com/rjanisis/p...II03788-02.PDF
2015 Acura TLX Trunk Trays
http://www.urvi.net/forumfiles/SB/BII51420.PDF
http://techinfo.honda.com/rjanisis/p...u/BII51420.PDF
Last edited by EE4Life; 12-13-2018 at 08:34 PM. Reason: Acura TLX Front Under Spoilers and Rear Under Spoilers were revised
The following 15 users liked this post by EE4Life:
2011TL (07-17-2014),
crownr0yal (01-06-2015),
csmeance (07-23-2014),
dwinnie (07-18-2014),
genejohn1 (12-12-2014),
and 10 others liked this post.
Yep! LOL!!!
One thread sticky called something like "essential technical documentation" would be nice.
Ps. Where are the instructions for the block heater? Up here in the true north and frozen this is the first thing i bolt on to my cars.
Grandpa
Received 2,609 Likes
What is the idea with the optional, dealer installed steering wheel?
George Knighton (07-19-2014)
Forum Contributor
Adding new accessory installation instructions. Mods will need to merge them with the original post.
2015 Acura TLX Front Splash Guards
http://www.urvi.net/forumfiles/SB/BII51875.PDF
http://techinfo.honda.com/Rjanisis/p...u/BII51875.PDF
2015 Acura TLX Engine Block Heater (L4)
http://www.urvi.net/forumfiles/SB/BII51660.PDF
http://techinfo.honda.com/Rjanisis/p...u/BII51660.PDF
2015 Acura TLX Engine Block Heater (V6)
http://www.urvi.net/forumfiles/SB/BII51455.PDF
http://techinfo.honda.com/Rjanisis/p...u/BII51455.PDF
Tonyware (07-19-2014)
Thanks for the block heater instructions. Once again the process says remove the front bumper even though there is no need to do so as I found out on my TL. There is enough space and openings to thread the wire around that area without removing the bumper, just the air duct and tray. Not sure why they do that, I guess maybe billing hours.
Forum Contributor
Adding new accessory installation instruction. Mods will need to merge it with the original post.
2015 Acura TLX Remote Engine Start System
http://www.urvi.net/forumfiles/SB/BII51876.PDF
http://techinfo.honda.com/Rjanisis/p...u/BII51876.PDF
JTRADAR61 (12-08-2014)
Forum Contributor
The following accessory installation instruction was revised and the link was changed from BII51410 to BII01138. Mods will need to update the original post.
http://www.urvi.net/forumfiles/SB/BII01138.PDF
http://techinfo.honda.com/Rjanisis/pubs/AI/AH/BII01138/enu/BII01138.PDF
Received 6,470 Likes
This thread has been placed as a Sticky.
The following 2 users liked this post by Steven Bell:
Rommel Orellana (12-05-2014),
tlxsteve (12-05-2014)
LinkDeny
LinkDeny
How do you get the PCM? Required for the procedure?
LinkDeny
LinkDeny
"NOTE: the PCM code will be required for this procedure.
1. Connect the HDS to the data link connector."
Does this mean that I can't just install it on my own with just the install kit?
Forum Contributor
They released one for the RLX, which is BII51837. To view it, just open one of the TLX techinfo links and replace the two portions of the link with the RLX number.
gottatlx (12-17-2014)
You can't do it yourself. The key fob's need to be programmed to the car, and it takes a special device that the dealer has - the HDS - which plugs into the car's data port.
2. From the System Selection Menu, select ONE-
PUSH START, then go to Registration.
3. From the Registration Menu, select KEYLESS
ACCESS Remotes, then select 2-WAY KEYLESS
SETUP. Change the setting to 2-WAY KEYLESS
mode.
4. Go back to the KEYLESS ACCESS Remotes
Registration Menu, select Add a KEYLESSACCESS
Remote, and follow the instructions on the HDS
screen. Do not bring the Remote Starter remote into
the vehicle until the HDS asks for the new remote.
5. Repeat step 4 for the second Remote Starter
remote.
6. After registration, verify all remote-related systems
work normally with all remotes
mode.
remote.
mode.
remote.
mode.
remote.
Rommel,
Mine charged $70 for programming 1 fob. I have a V6 Advance which comes with only 1 engine start remote. I ordered the other fob online, and saved $60 on the part, then took it to the dealer to program.
Forum Contributor
2015 Acura TLX Spare Tire Kit (2WD ADV & ALL AWD)
http://www.urvi.net/forumfiles/SB/BII02017.PDF
http://techinfo.honda.com/Rjanisis/p...u/BII02017.PDF
2015 Acura TLX Spare Tire Kit (2WD BASE & 2WD TECH)
http://www.urvi.net/forumfiles/SB/BII02031.PDF
http://techinfo.honda.com/Rjanisis/p...u/BII02031.PDF
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
