XLR8 ISC Coilover Sale!!!
![](http://i34.photobucket.com/albums/d121/Excelerate/XLR8LogoJPG.jpg)
We've gotten a lot of positive feedback on the XLR8 ISC coilovers and we want to get some more feedback and images. So, basically, we want to get more coilovers on customers' cars. So for the next 2 weeks we are going to offer a one-time sale of $850 plus shipping on all XLR8 ISC Coilovers.
![](http://d5otzd52uv6zz.cloudfront.net/486ce5c0-e6aa-4480-8ee7-47c9939028ba-800.jpg)
Choose your vehicle here:
http://store.excelerateperformance.c...s/g-65477.aspx
So what are XLR8 ISC coilovers and what are the benefits?
The ISC N1 Coilover is an affordable high performance damper system which offers excellent performance and high quality at a reasonable price. ISC offers suspension solutions for various auto manufacturers including BMW, Ford, Honda, Hyundai, Lexus, Mazda, Mitsubishi, Nissan, Subaru, Toyota, Volkswagen, & more! But we are going to focus only on the Acura lineup.
All coilover setups come with a 12 month warranty to put your mind at ease; if the product fails in any way in the first 12 months we will pay all postage, labor and parts costs to fix the issue, and in minimal time. If our product fails after that initial 12 month period we will replace the product at trade price!!
The N1 coilover can be lowered approximately 3 inches lower then standard ride height. The spring rates are set up specifically to suit your car and therefore will improve handling and stability dramatically. We can make packages for track/rally/drag and of course street. Our lineup will specifically be designed towards the street/sport customer. However, to offer more flexibility we will offer the option for custom spring rates at no extra charge. This will require extra time though depending on what is in stock.
Features:
32 Steps of Damper Adjustment
Precise control of valving/damping (rebound only)
Operates smoothly on all road surfaces
Expansion/Suppression of shock adjustment
Pillowball Uppermount (RSX) or Aluminum Upper Mounts
Adjustable camber allows more/less on road track for all conditions (RSX only)
Piston Rod Design
Strengthened steel piston rods
Meets race/sport standards
Sports Spring
Made from high quality SAE9254 steel
Tested over 500,000 times on compression inspection with less than 5% deformation
Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application, for specs check the application guide or ask us when you order, custom spring rates are free). Spring rates are typically as follows for the Acura models: Street Comfort 10/6 Street/Sport 12/8 Track/Race is 14/10.
Ride Height Adjustable
Full length height adjustable
Pre-load adjustable with separate spring locks
High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force
Aluminum Bracket
Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance
Specially anodized surface to prevent internal corrosion and surface rust
On various models camber can also be adjusted via the bracket as well as the camber tops (RSX only)
Single Cylinder Design
Monotube construction
Larger cylinder and piston design to advance driving stability and dexterity
Thrust Bearing
Improves steering and creates a smoother ride
$55 upgrade included for free on all our coilover kits with Macpherson style struts
Can these coilovers handle Canadian winters? As you may be aware up North we are exposed to snow, icy conditions and freezing temperatures. In addition the municipalities use salt to combat icy roads. The negative byproduct of adding salt is it hastens/adds rust to components underneath the car. How will warranty be applied if at all to those who drive in harsh conditions?
The warranty is 1 year regardless of location.
08_UA7_Gr33k
02-11-2016 02:17 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
