TSW Nurburgring what width and offset?
Hey,
I'm about purchasing a 20" set of these, I need a little help with the offset and size. Some online websites I used suggest I go with 20x8.5 with a 43 mm offset. Although the TSW website itself suggests 20x9 with a 35 mm offset.
Which one should I lean more towards? Would there be any noticeable difference in appearance between the two? I'm running a stock setup and don't have any plans to lower at the moment, I DON'T want to roll my fenders or have any rubbing issues (went through that hell with my last car, never again...)
Thanks in advance!
Thanks in advance!
If you're not planning on lowering the car, I would recommend the 20x8.5 +43. The 20x9 +35 will look better if lowered.
20x9 +35 on stock suspension:
Attachment 103163
Same thing but lowered about 2":
Attachment 103164
As for rubbing, you'll be fine as long as you stick with a 245/35R20. 255's or wider will most likely rub in the rear over big dips.
Attachment 103163
Attachment 103164
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
