Is toe adjustable without aftermarket parts?
justnspace (02-18-2015)
We offer camber kits from Ingalls, SPC and more. I recommend the Ingalls kits for the most part. We find they have the most adjustability and the best quality bushings. You can get the Ingalls rear SmartArm link and ball joint kit for $145.84. You would need a quantity of 2 for both sides.
Ingalls Alignment Kit - Excelerate Performance - Japanese and European Performance Specialists!!
Xlr8... what exactly is available for the 2012 sh awd front and rear?
I am having a little difficulty deciphering the products because the description doesnt seem to match the product... or is a generalized description as opposed to a specific description.
For the front, and we have two different kinds of ball joints depending on how much camber you want to adjust for. The first kind can adjust between +1.5 to -1.5. That is part number 35592. Link:
The second type of ball joint we offer for the front can adjust between +1.5 to +3 degrees of camber. I would recommend this kit for cars that are lowered and have more than 1.5 degrees of negative camber. The part number for them is 35593. Link:
Keep in mind the ball joints are sold individually, so you would need to buy a quantity of 2. In terms of toe adjustment for the rear, we offer the SmartArm adjustable link. You can pair this with the rear adjustable ball joint to adjust camber as well. Just the rear arm link for toe is part number 38623.
The combination arm link and rear ball joint part number is 35623. This allows for a range of +3 to -3 degrees of camber and toe adjustment in the rear.
Hopefully this makes some sense for you, as the product descriptions on our website can be a little vague.
trinikidcl
09-04-2015 12:56 AM
