Tires and interior rattle
Hey guys, i understand alot of people with the tl are affected by interior rattle noise. Will switching from stock tires to some more expensive / better tire resolve rattles? If it worked for you, what tires did you opt for? I'm shawd model
Yeah, what ^^^ said. I have the same issue. Some minor rattles in my headliner as well as the seatbelt adjustor on the driver's side. It seems to be pretty common in 4G TL's. Make sure it's not your sunglasses in the holder that's causing the issue...that wouldn't be a first.
I read somewhere that if you remove the headliner there are clips or something similar that can be taped down to eliminate the noise. You can also dynamat the rear deck as that may be a cause as well (or have dealer take care of it).
Good luck!
Good luck!
6G TLX-S
High performance tires tend to have more rigid sidewalls and thus an even rougher ride on the SH-AWD TL. They will make the rattles even worse.
marcelft
07-10-2018 06:17 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
oyayjoe
09-12-2015 04:40 PM
asahrts
09-04-2015 05:55 PM
