Tire Pressure for 2013 Acura TL AWD Advance
Hi all Acuras
I have 2013 Acura TL AWD Advance. The label said the tires require 34 PSI cold. I pumped the tires to 34 PSI and found all tires (on tire monitor) went back to 32 PSI after few days. I tried twice already and has the same problem.
I found the ride on 34 PSI cold is better. DO anyone experience the same problem? Do I have leaking tires? Advise please.
Search first. There are several threads already on this specific subject.
Hint on searching: DO NOT USE the big search box in the middle of the screen. Instead, find the section you wish to search, such as 4G, tires, wheels & suspension... then use the drop down box on the top of the right hand corner of the thread list that says, "Search this Forum."
6G TLX-S
If pumped to 34, the next day will drop to 32.
Then try pumping the tires to 36, and see if the next day the pressure will drop to 34.
Zonian22
11-14-2015 01:20 PM
Nitin
09-30-2015 08:22 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
Zonian22
09-02-2015 08:19 AM
