Tire Cupping or Feathering?
When I bought my 2009 TL SH AWD on Monday I knew the tires where not great. However after driving it all week I noticed the rear tires looked cupped or feather. I didn't notice this when I purchased. My question is does this indicate a vast number of things that are wrong with my suspension or one particular problem. Also if anyone is considered an expert what kind of $ am I going to need to start saving. The obvious new tires $500-$700 I am aware of.
Latent car nut
Received 2,005 Likes
Cupping on the rear tires is not at all unusual and not necessarily an indication of an issue. I've found rotating the tires regularly helps a bit.
1dcress (03-03-2018)
Yes the tires seem to be more than a few years old. I guess I’ll have to take it in to just get everything checked. I don’t want to put a new set of tires on with suspension/alignment issues.
KCCO
Rotate your tires and get a four wheel alignment. Then keep an eye on the wear to see if it’s still a problem. I think doing those two things may fix your issue.
1dcress (03-12-2018)
aameghoo
11-18-2013 12:36 AM
