Replacing one tire
KCCO
Replacing one tire
If a SH-AWD has three tires that are good with 7/32 inch tread on them, and one tire needs replacing due to a sidewall chunk missing, is it possible to replace just that one tire? A new tire has 10/32 inch tread, so there would be 3/32 difference between them. I wouldn't want to mess up anything in the driveline, but the tire shop has said that it won't affect anything due to the minimal difference between the treads. Just looking for your input. If tires were cheaper I wouldn't have a problem, but the 19" tires go for 394 a piece.
I don't think the 3/32 difference is enough to make a difference. The first 1/32 of a new tire tends to wear off quickly, so that makes only a 2/32 difference. If it was me, I would go ahead with what the tire shop said and take the vehicle and keep your eye open for any problems. Keep in mind that it's not uncommon for tires to wear differently without causing a problem on your car. For example: say you forget to rotate your tires. Excessive tire wear will set in which also won't set a trouble light. I say go ahead and just replace one tire.
justnspace (07-21-2017)
Stay Out Of the Left Lane
Received 1,236 Likes
I tend to agree with others here and say replacing one tire is fine. For me personally, when I have had to, I have replaced in pair or sets. Just out of curiosity what tires are you looking at for 394?
To me your are fine to replace 1 tire. I have 1 at 10/32 and the rest are 5/32 or 6/32. Same thing happend.
The car has SH-AWD. Which means power is sent to each wheel independently. I could see a small issue if it was a locked 4 wheel drive setup where they all turn at the same time at the same rate. Even with that stated what happens when you turn the car... tires move at different speeds without any problems. So i personally think its BS who ever came up with that.
If you're whining about $400 then you won't like a bill of $2000+ for replacing a differential.
Whether 3/23 is ok or not I wouldn't risk it. Even if that is acceptable there will be additional wear due to the difference in circumference. Just not enough difference to cause damage to the differential. Keep in mind that excessive wear is cumulative.
I would do whatever it takes to keep the tires exactly the same including circumference... Shave the tire to match, two new, used but unlikely given it's not a common tire.
I don't think it's worth the risk to nickel n dime something like this. This is the price you pay for driving an AWD vehicle.
It's not the same system, but my Honda Pilot seems to be fine with having different wear on tires. Reading on Piloteers.org, a ton of people have encountered situations where they used tires at different treadwears and none have had any problems. However, like I said, the Pilot 4WD system is completely different than the SH-AWD so it's not really apples to apples.
KCCO
It's a replacement OEM Eagle RSA. I'm not happy about the tire choice Acura went with for OEM, but until these are used up I'll have to live with them. The shop gave me a deal for $313, but it still hurts lol. Thanks for the replies. I ended up calling the local dealer and spoke with their service manager. He said it wouldn't be a problem at all, so that's what I did. The actual depth of two of the tires was almost 8/32, so it's even less of an issue.
I was able to pull this from a honda manual.
Tire Replacement Acura recommends that you replace tires in sets of four, or in pairs, front or rear. If you need to replace only one tire, mount the new tire opposite the tire showing the least amount of wear. For instance, if the left front tire shows the least amount of wear, mount the new tire on the front right side. The original tires on your car have tread wear indicators to indicate when they should be replaced. The indicators appear as bands about 12.7 mm (1/2 in) wide when the tire tread depth is less than 1.6 mm (1/16 in). When indicators appear across two or more grooves in a row, you should replace the tire.
In short, best tires go upfront.
In my cars case.
FL is 8/32 FR is 10/32
RL is 5/32 RR is 6/32
Secondly you can order a new tire and have it shaved down to match. If my 8/32 tire wasn't so new and was like the rear's then you could have it down to 6/32 and just replace the 1. Way cheaper than replacing all 4 after every pot hole.
In my cars case.
What did you end up doing? Did you go with one tire or two tires or all 4 tires?
The only thing with that is that you are not suppose to drive on the spare tire for few years, only few days and only up to 50mph like you said; hence, the tire is not the exact match cause it probably wont matter for such a short period of time and driving conditions.
I hate to revive the old thread, but I am in the exact situation. Our TL has only 19k miles on the OEM tires. They are down to between 6/32 and 7/32 and we are in a need to replace one of the tires due to sidewall damage.
Latent car nut
Received 2,005 Likes
KCCO
Thank you for brining this concern! Valid points given the limited information; however, in my case, this was actually my 2nd set of the OEM tires. The TL we got was CPO with less than 30K. The original tires developed nasty vibrations cause the car sat on the dealer lot for many weeks due to the Takata recall before the dealer was able to sell it. After going back and forth with the dealer, they agreed to replace the tires, so these tires are about 18 months old. If they were the original tires, I agree, I would have replaced them all without questioning myself
horseshoez (07-24-2018)
I ended up replacing just the one tire. A year later they are all still good. I just measured the other day before a trip and the new tire is 9/32, and the other three are all around 7/32 still. Again, an Acura mechanic had told me that a difference like that wouldn’t affect anything.
