Rear camber kit needed?
Putting on tein street advance and planning on dropping it 1.5-2" to get the tires to fender. Can anybody confirm if I need rear camber kit t get the alignment in spec?
SPC has a three arm kit which is about $400 for the pair and ingalls has ball join and arm kit for $300 for the pair.
Just trying to figure out if I should get these or not.
sigbrown1297 (10-23-2015)
Former Sponsor
Yes with a 1.5-2" drop you will want a rear camber kit. The SPC 3 arm kit can adjust + or - 3 degrees of camber and is available for $211.98 per side, so you'll want to order a quantity of 2.
SPC Control Arm - Excelerate Performance - Japanese and European Performance Specialists!!
Not hitting the fenders right now, but got the fenders rolled last night so that when i correct the camber, it won't hit.
spc ball joints make alot of noise... thats all i gotta say.. about 5 people already have confirmed that issue and resorted back to putting stock ones back on
Former Sponsor
I'd written two articles on the matter... see here:
For camber rear kits, avoid parts with aftermarket ball-joints.
and here:
Honda/Acura Ingalls vs SPC Rear-Camber Kit Debate: 2015 Update
and here:
you shouldnt. but since camber is not adjustable and if its out of spec, the only way to get it into spec is getting a camber kit.
remember, every one's set up WILL BE DIFFERENT, so there is NO ONE SIZE FITS ALL advice.
it also depends on how you want the alignment set up....
if you want it in spec from the factory, or if you would like to ADD camber.
so, there are tons of different variables that affect your question....
the best advice is to;
- lower the vehicle
- get an alignment
- asses situation.
- if needs camber, add camber kit
omgitsspooky (07-13-2016)
My advice, get an alignment first and if you're within spec then don't get it. For our cars, anything under -1.8 degrees is acceptable. You can go back and get another alignment free of charge after the camber kit is installed.
The following 2 users liked this post by TeamAcura:
justnspace (07-13-2016),
What shop were you referring to?
The Original Shawdy
omgitsspooky (07-14-2016)
Firestone in my area (Wichita ks) wanted $180 for an alignment. They said I couldn't get their lifetime alignment either since I'm dropped on coilovers. So I think it varies region to region.
Syms
08-30-2016 08:07 AM
anakin44011
10-30-2015 07:40 AM
Chuckle
10-22-2015 09:06 PM
