Question about Tire Pressure
I recently had my '10 TL serviced at the dealer and they inflated my tires to 37 in the front and 36 in the back. Is there some reason they always put way more than needed? The manual clearly states 32 in both the front and back on the FWD model. Should I be letting some of that air out or just leave it at 37/36? Just curious...
Thanks!
Thanks!
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
wait till the tires are COLD; (next morning)
I keep my 2012 TL/SH/AWD, 18" Michelins at 35PSI/COLD
Handling is better, & I've found through experience, there's no extra tread wear
odinsride (03-05-2012)
it can drop about 4-7 psi depending on weather conditions.
in socal, we have very cold mornings and very hot afternoons.
my car reads 31-32 psi in the morning, and when i leave work.. its at about 36 psi.
you dont want it to read 37 psi at cold weather becuase if its hot, you can easily go over 40psi and that is not good.
Big mo (10-30-2012)
6G TLX-S
I run 35lbs of Nitro all around.
Oops...inline edit: the nav manual says that since I didn't input a value, temp is the only selectable item. I'll try again this evening, but I was certain that pressure was an option under the "Automotive" heading. I could certainly be wrong, though.
Being almost certain that I've done the pressure conversion in-car before, I went down to my parkade just now to double-check. For some reason, it would allow me to convert only temperature.
Yes it does temperature, but you may be able to simply set your MID to show in C. Under "Calculator", simply input the number you want to convert, and then push the joystick downwards for "unit conversion". Temp is item 5 on the list, I think. Presure is found under "Automotive" (item 6).
6G TLX-S
No luck.
Inside the "Automotive" page, even though "Pressure" shows up as one of the multiple entries, it is greyed out and can't be selected.
In fact, only the "5. Temperature" entry is working, the rest of the entries are all greyed out like the "Pressure" one.
converter on the dash is too slow, i just use my blackberry... lol
