Progress 22mm RSB
Progress 22mm RSB
So I ordered the 22mm Progress RSB. I'm curious if anyone is running this newer revised version (old version was 24mm) and if they have any info on the difference between the soft and stiff setting.
I'm probably going to just put it on stiff but wouldn't mind some feedback if any members has used the bar on the difference between the two settings.
The Original Shawdy
In for your review.
carbonTSEX (03-11-2016)
The Original Shawdy
It's super easy but maybe Wreak will be kind enough to make one for you once his arrives.
Here is the instructions that Progress has on their website:
http://www.progressauto.com/ecom/download/62.0111.pdf
I'm also pretty sure I stumbled across another member who posted a DIY on this site.
The bar has touched down in my garage, I'm excited to install it since fun mods like this have been few and far between since my son was born.
It seems like a pretty solid unit, I will weigh it to compare to the stock bar during install, I'm curious how much heavier it is.
I've decided to set it at the stiff setting when I install it. Review and pictures to follow. I'm hoping to install it this coming weekend. Stay tuned.
carbonTSEX (03-23-2016)
Install should be coming soon, I had to grab a few things, 13/32" metal drill bit, teflon tape, lithium chassis grease (because I don't think the grease they gave is good enough), and a 5mm hex since the one I had wasn't going to cut it.
just remember, you have to make the original bolt holes that hold the rsb to the frame bigger this going back to stock is kinda not possible as the holes are no longer snug.
the metal is very thin down there.. i would go get a 22mm if i was not on air. but since i am it is useless.
The Original Shawdy
That sucks that it isn't compatible with the factory size hole and non reversible.
2G TLX-S
What if the aftermarket sway bar tear up the rear chassis mounts again ?
Does it mean the car is toasted, being no longer able to install neither the OEM nor the aftermarket sway bar ?
I have the Progress bar 22mm installed on the soft setting, was told the stiffer setting will put too much stress on the thin mounting points. So far no problems with it for over a year.
Did you notice much of a difference with the new bar on the soft setting? Are you FWD or SH-AWD? Who told you the stiff setting will put too much stress on the mounts?
2G TLX-S
Only time can tell.
Meanwhile, we need more of those, who have installed the newer 22mm bar, to report back again in a year or two from now.
carbonTSEX (04-14-2016)
My car is a 09 FWD and yes you can tell the difference right after installing the 22mm sway bar, the car feels like on rails and feels more together, IMO this is the best upgrade you can do to your car and it is cheap. And about messing up the mounting points/rear frame I remember reading it in this forum 4G and 3G owners. My advice is stay in the soft setting.
2G TLX-S
If it is a FWD trim model, then installed the OEM AWD-TL rear sway bar will also have similar effect, because both the AWD front and AWD rear sway bars are thicker/stiffer than those on the FWD trim model.
In addition, the factory AWD-TL rear sway won't risk damaging the rear mounts, since it is OEM on the 4G AWD TL.
There's a diy for the 4g TL AWD rsb swap onto a Accord Contour so me guessing it would work:http://www.crosstourownersclub.com/forums/showthread.php?t=4433
Finally installed this today, I put it on the soft setting and what a difference in handling! Feel free to ask any questions, it took me about 2 hrs to install alone. I didn't unbolt the lower control arm like the instructions say and was able to slip the old bar out and new bar in with some maneuvering. I took some extra steps to avoid squeaks, more lube and Teflon tape. Can't wait to take it for an extended drive to really test it out. I took a couple pictures with a potato that I'll post later.
Has it been confirmed that the 4g AWD sway bars will fit the4g FWD? If so I'm in, if rather do that swap than drill into the sub frame! It wasn't really confirmed in this thread: https://acurazine.com/forums/tires-w...-747113/page2/
There's a diy for the 4g TL AWD rsb swap onto a Accord Contour so me guessing it would work:DIY: Acura TL AWD rear sway bar to Crosstour upgrade - Honda Crosstour Forums
So I've had a chance to do some driving but nothing really aggressive yet. The car feels more buttoned down in the back, steering even feels more precise and body roll has decreased by a lot, the car is very flat in the curves/sweeping turns in the soft setting.
Here are a couple pictures:
Progress 22mm 09-14 Acura TL sway bar comparison to OEM FWD bar
Progress 22mm 09-14 Acura TL sway bar installed
No regrets
No regrets
So I have some additional feedback even though it seems that nobody really cares haha.
I'm convinced that this bar has helped to reduce some of the creaks in the interior while driving on uneven pavement, which makes total sense since the chassis doesn't flex nearly as much with it. I'm very tempted to go to the stiff setting and see how that feels...
carbonTSEX (05-12-2016)
The Original Shawdy
We care and like hearing your feedback as everyone was scared due to Pots experience.
Thanks for the update Wreak. How do you feel about the understeer/oversteer balance? On my old Accord I threw on a TL Type S OEM RSB, and there was so much oversteer it was a little frightening, and that car was just a 4cyl. I can't imagine what 280HP would induce if the same thing applied to the 4G.
It definitely altered the steering dynamics by a lot, the instructions say to always put it on soft and test drive in a safe area to re-learn how the car responds to steering inputs. You get used to it and I've not felt like the car is unpredictable in anyway, but I wouldn't recommend to install this and hop on a twisty road driving like a a madman, because you really have to adjust how you steer afterwards.
I will definitely move to the hard setting at some point in the future and will follow up with any feedback on how that feels over the soft setting.
carbonTSEX (05-19-2016)
2G TLX-S
Stiffer front shocks than rear shocks will induce more understeering.
Stiffer rear shocks than front shocks will induce more oversteering.
As such, it is possible to tune the resulting car from heavy understeer to neutral handling, and even all the way to heavy oversteer, to suit each driver's unique driving style.
8th Gear
Thanks for the feedback... I think I will end up going with this mod later this summer. I just changed over to 19" Gram Light wheels with Michelin Pilot Super Sport tires a week ago and am loving it. Probably should wait for a while to get used to the setup before making any changes...
My understanding is that the SH-AWD uses a 20mm rear bar, so while the difference wouldn't be as noticeable as it is on the FWD it would still be an upgrade. I would also bet that the metal on the ends of the bar is really thin on the SHAWD bar versus beefy like on the progress bar so that would also help.
