original '7 series bmw rims on 4th gen
Old 09-07-2016, 05:56 PM
5th Gear
MisterCipolla's Avatar
Looking to grab a set of 19 inch 745 rims .Any input .
Old 09-07-2016, 08:34 PM
Received 8,568 Likes on 6,621 Posts
ebay
Ron A (09-07-2016)
Old 09-07-2016, 08:42 PM
5th Gear
I'm not looking to buy on this thread .Im asking if anybody has done or seen done too and any input with the offset when it come to sizing .Ex will they rub
5th Gear
Think of putting either 745 19 inch or M5 19 inch both are same bolt pattern
Old 09-07-2016, 09:57 PM
The Original Shawdy
carbonTSEX's Avatar
Seen it done before. They will fit but you'll need to run hub rings adapters. Rubbing will only come into play depending on if you're lowered.
Old 09-07-2016, 10:06 PM
5th Gear
I just bought the 19" M5 joints and currently waiting for my tein coilovers to come in but What do hub rings do and why do I need them ?
Old 09-07-2016, 11:02 PM
The Original Shawdy
carbonTSEX's Avatar
BMW's run a smaller hub size. Without running the correct hub size you may run into vibration. You can buy a set for $10-20 from most tire shops.
Old 01-11-2017, 08:54 PM
4th Gear
Jazzkanda6's Avatar
Is that all you would need to do? Offset is usually off. I'm looking at getting rims and having a hard time finding much.
Most BMW's are 5x120, (not sure about 0.68)
And 55 offset. I know the bore is off. So get a hub converter and you're all good? Even on an awd wouldn't have a prob? Assuming there's no staggering
Old 01-16-2017, 04:42 AM
herbert6368's Avatar
He's not saying about the bolt pattern, he is talking about the hub bore, bmw is 72.6mm our car is 64.1. So you need hub centering ring
Old 01-18-2017, 02:06 PM
umber1's Avatar
hubcentric rings is all you need
Old 02-14-2017, 09:54 AM
Former Sponsor
ExcelerateRep's Avatar
For a couple dollars more per rim you could get yourself a set of Rotiforms!
They're running a buy one get one free sale! PM me for quotes!
Crazy Bimmer
06-16-2020 09:14 PM
12-21-2017 02:33 PM
pimpin-tl
07-11-2016 01:39 PM
John Ngo
04-20-2016 09:24 PM
CincyAc
03-07-2016 12:00 PM
Quick Reply: original '7 series bmw rims on 4th gen
