Lug nut socket size?
I searched around and couldn't find an answer. Does anyone know what the size of the stock AWD lug nuts are? I am getting a torque wrench and picking up sockets to swap my wheels and I don't know what the size of the socket is to take the OEM wheels off.
Any ideas? |
Originally Posted by petec2010
(Post 11909879)
Any ideas? i was sent 12x1.5 which is wrong size :annoyed: they're sending me 14x1.5 tuner lugs now to fit, if you wanna wait till tuesday i will confirm once they try again. :wish: |
Actually I need to know the size of the socket that you put on the lugs to take them off. 14x1.5? Which one is the socket? 14mm? Seems small.
Ok looks like the answer is 22mm socket size. I think that converts to 7/8th.
Mods, I think I meant to put this in Tires and wheels. |
(Post 11909928)
No, the 12 x 1.5 or 14 x 1.5 is related to thread pitch. Honda had aways (mostly always?) been 12 x 1.5, I'm surprised they changed. Pete, your looking for Lug Nut socket size, which I guess you've now determined to be 22mm. |
Yeah, should be 22 mm deep socket, which I got from Sears. That is actually the size for the RL and MDX, but I do not expect the 4G TL to be different.
Originally Posted by Chas2
(Post 11911368)
7/8 will work also
Originally Posted by Six Shifter
(Post 11912118)
7/8 will work also
Ahh thanks, I wondered what the imperial (is that right) conversion was for the metric size. |
1 inch = 25.54 mm.
22 / 25.54 = 0.8614 7 / 8 = 0.875 Off by slightly more than 1/100th of an inch...close enough. :D |
So what is the size of the threads themselves? I tried my 12x1.25 and 12x1.5's yesterday on the new wheels (while I'm waiting for the real ones to arrive) and they don't fit. I saw 14x1.5 above. Is this the correct size?
14x1.5 is correct
Originally Posted by Kingmeow
(Post 11912916)
1 inch = 25.54 mm.
22 / 25.54 = 0.8614 7 / 8 = 0.875 Off by slightly more than 1/100th of an inch...close enough. :D 1"=25.4mm not 25.54mm.... |
True, however this line ->l<- is bigger than the difference between 25.4 & 25.54mm.
-and- This thread died over three years ago. |
Hi
Could you tell me what size impact wrench you got is? To take wheels off? Ty
| All times are GMT -5. The time now is 09:01 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
