Lowering springs/Alignment question's
As I said in my earlier post I lowered my 2012 TL SH with 1.4" springs. I read on this site some saying that if you only lower car 1-2 inch that the camber won't be out of whack but if you lower 3-4 inch the camber will be messed up.
My question's are is there camber adjustments to be made on the rear or do I need to buy more parts? And do you think 1-2 drop will throw the camber way off and last does anyone know what the camber specs are on this car?
Thanks in advance for your time and help. First time Acura owner here.
Drive around for a few day and allow the Springs to settle a bit, you will have to get an Alignment. The Camber should be between -0.5 to -1.8 degrees IIRC.
McTBoyz (04-01-2018)
Had the alignment done today. I was told there is in rear camber adjustment and that I would need to buy the rear adjustable camber kit to get it back into specs. The rear max spec is -1.8 and mine is -2.6
gotguinness?
06-26-2007 09:34 AM
BlueCLS6
02-07-2003 11:42 AM
