Lighest, Most Handsome 18x8 Wheels That Fit
After some extensive searching on Tirerack and Wheelweights, I'm still stuck with the Enkei RFP-01 (18x8, 5-120, +40). Unfortunately, I think they're really ugly and belong on an Evo but not a TL. ![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Can anyone here please give me guidance as to which 18x8 (or wider, if there are no rubbing issues) wheels are the lightest fitment for the TL?
Why worry about the weight, I would recommend finding something that you like the looks of. Adding or subtracting a couple lbs of weight for each wheels isn't going to be as noticeable as you think.
What is your price range for wheels? The lighter you go the more expensive you're going to pay. Maybe some forged work wheels?
I'd say I'm willing to pay up to $500 per wheel if the wheel is substantially lighter and stronger.
Thanks for the tip on Work wheels.
Unsprung weight reduction may be difficult to feel but the benefit is measurable. Along this line of thinking, the TL has a forged crankshaft but a cast one could have been used instead. The summation of many little things makes for improved performance.
I think @$500 a wheel you would probably only be able to find something one or two lbs lighter than stock... you don't want to go too light, then you'll have the problem that the wheels will just spin and you won't get any traction.
I wish the mythbusters would do something on this, would love to see the results, to see how much difference the weight of wheels would make.
Also I think BBS has some 5x120 18's that are pretty light as well. Good luck on the search.
Do you know what the stock wheels weigh, by chance?
And even if you could get wheels that only weighed 1 pound each, you wouldn't just spin your tires. Remember that the rest of the 3800+ pounds of the car is supported by the wheels & tires.
That 3800 lbs, distributed on each wheel, is 950 lbs per wheel. 950 lbs is a lot of normal force on each tire; that normal force, when multiplied by the coefficient of friction of the tire on the road, translates into tremendous frictional force. Spinning the tires from a standstill would not be possible on the stock tires and regular road surface (assuming you didn't just dump the clutch from like 5K RPMs), even with ultra-light wheels/tires.
I'm looking at one of the wheels below.
OZ Ultraleggera (18x8, 17.6 lb)
Forgestar F14 (18x8.5, 17.6 lb)
Here is the info I posted previously about the stock 18" AWD wheel.
When I weighed my 18" AWD wheel, it came in around 52-53 lbs and that's with the tire obviously. Tirerack lists our factory tire at 27 lbs, so a fairly good guess of the 18" wheel itself would be around 25-26 lbs.
The "lightweight" thing doesn't make sense to me on a 2 Ton car... You'd be better off ripping out all the tech, HVAC, electrical system, seats, dash, etc... than by shaving 5lbs per wheel off the car.
I'm just saying that you should look for wheels that you like the look of, before you look for lightweight ones... If you find both, awesome!
http://www.nerocam.com/SCC_TAP.asp
These guys dropped 13Lbs at each corner and they were able to drop:
60-0 stop: .1 second faster
1/4 Miles - .3 second faster
0-60 - .5 second faster.
So, you can totally make your car faster with lighter wheels, but you'll make your car much faster by stripping the interior.
By the way - that article above it comedy gold, I hightly suggest reading it
![](http://www.nerocam.com/SCC_Images/image033.jpg)
Also, in April when I put my 20's back on, I'll weigh both, and post up some feelings on the difference, I'll weigh the 18's with tires with my 20's with tires to get a feel for the weight difference/total on both. I can't wait to see if I can notice a difference with them... It could be huge.
There's arguments to both sides. If someone has it in their head that they want to get a light weight version of a wheel, why not? The fraction of a second improvement in acceleration, braking, and handling could be the difference on the road in terms of safety. I for one like to improve upon the car's performance. I'm not saying you gain a second in the quarter mile, but I do believe you will experience better handling and better all around performance. Another important aspect to realize is that the tire is very important to the weight. The moral of the story is to research.
Back From The dead
![Blink](https://acurazine.com/forums/images/smilies/blink.gif)
![Not Funny](https://acurazine.com/forums/images/smilies/notfunny.gif)
I have car ADD
To the OP
Enkei RP03
![](https://img10.imageshack.us/img10/6783/dsc05010j.jpg)
![](https://img199.imageshack.us/img199/6340/img255789hdr800.jpg)
I had them in 19"s
for the 4G (5x120), you can get
18 x 8.0 + 45
19 x 8.5 + 35
19 x 8.5 +42
My 19 x 8.5 wheels were about 20.xx lbs.
My 19 x 9.5 wheels were about 21.xx lbs
I would image the 18" wheels is around 19lbs
Beautiful and strong wheel IMO
Enkei RP03
I had them in 19"s
18 x 8.0 + 45
19 x 8.5 + 35
19 x 8.5 +42
