Gorilla Wheel Lock System installed... lock on every lug!
My area has been subject to wheel theft. I did not get the factory wheel locks because I prefer the aftermarket systems that have a lock on every lug.
But here is the bad news... I pulled off my factory lug nut. Not only is the thread size 14x1.50, but it's a ball seat. I cannot find ANY wheel locks with these specifications. It looks like I'm forced into getting Acura's.
If anyone has any suggestions let me know.
Last edited by Bearcat94; 04-06-2009 at 12:20 AM. Reason: Change Title per OP request
Not sure what part of NY your from, but in Queens, there is a place called 106th Tire. It's on the corner of 106th street and Northern Blvd. They sell a lot of different wheel locks. They may have what you are looking for.
My area has been hot for stolen wheels lately, so I got thinking. I never liked the 1 lock per wheel, I felt it did very little to deter thieves. There were some issues getting a full wheel lock system. Our lugs are 14mm x 1.50 with a ball seat (no system exists for this setup). The acorn seats have too much of an angle and will damage the wheels. So my solution to the problem, pick the acorn wheel lock system and I found washer adapters specifically to fit to acorn lugnuts at 14mm and create a ball seat mount point. I will post up some pictures in a bit. The only downside is that they stick out about half inch further than the stock lugnuts, but I like the aggressive look.
AZ Community Team
Received 7,770 Likes
Why did you start a second thread?
Threads Merged.
Threads Merged.
AZ Community Team
PM a mod next time and they can do the fix up, instead of stumbling across it.
Titles carried over from the merge; fixed.
Sorry for the interuption. Carry on.
Here are the pictures.
Wheel Locks, Gorilla part #71644 (yes, I ordered the 6 lug set, this way I have extra lugnuts that fit the same key, fyi gorilla will not send you matching lugs to a key, they can only replace a lost key)
Washers, Empi part #00-9508-0 (14mm opening, adopts acorn style lugnut to have a ball seat, picked them up on ebay for about $3/pack)
As I said they stick out a bit, but they create a slightly more aggresive look and overall with the car looks good.
Does the part sticking out turn freely or is that part of the lug nut? Because if the part sticking out is solid and can turn the lug nut, I could put a large easy out on that and turn them right off. Also might be able to get a nice pair of vicegrips on them. But theives are looking for easy, so they will probably pass you up, since it's extra trouble. When they steal the wheels in your area, are they leaving the car on blocks or dropping it on the ground?
OP, great idea on the added security for the wheels...I'm just not real keen on the whole washer between the lugnut and wheel thing.
Received 6,470 Likes
A friend of mine just got some for his Type S and really likes them. He needs them-he's in NYC.
National Acura Meet-June 6th/Kansas City-LESS THAN ONE MONTH AWAY!!!.
Click here for details and to sign up!
This whole setup is only temporary until I get some aftermarket wheels.
Very interesting solution! I think this is pretty cool!
How thick are the washers?
Do you have an idea of how many turns on the lug nuts you have with the washers vs without the washers?
What are the washers made of? steel, aluminum?
Any concerns of the stud not being long enough?
Thanks!
Thanks!
Thanks!
Thanks!
My primary concern was achieving proper torque, and to maintain the torque while I drive. I've gotten some people who say nothing, and some people say it's a terrible idea. I get plenty of turns on the lugs. I can't say how many, but I felt very comfortable with it. I use my torque wrench to get them at 80 lb. I got this idea from my girlfriend's Lexus. From the factory, the lugs use a washer to help seat it. Again, I can vouch over a year on this exact setup without every experiencing loose lugs or any problems with the wheels or studs.
mada51589
05-03-2022 08:54 PM
braveheart
09-07-2015 08:12 AM
