Front and rear camber kits
Old 01-20-2017, 08:41 AM
NtnBeatsMuzik's Avatar
hey what's up guys. I just got my car back from the shop after install my bc racing coilovers and just found out I need a camber kit 😏 I have an Acura TL 2010 sh awd anyone know where I can get a good camber kit front and rear ? Thanks
Old 01-20-2017, 10:39 AM
jtech316's Avatar
both vendors on the site.
www.excelerateperformance.com
www.heeltoeauto.com
Old 01-20-2017, 08:30 PM
The Original Shawdy
carbonTSEX's Avatar
I recommend going SPC 3 bar rear kit (1 per side) and SPC front adjustable ball joints.
Old 01-21-2017, 12:41 PM
aleo12's Avatar
Hey, sorry to thread jack!
But random question, will camber kits work on stock suspension?
I went for an alignment at the dealer a couple weeks back 3 wheels are sitting at -2 camber and they said these cannot be adjusted
Old 01-21-2017, 01:48 PM
The Original Shawdy
carbonTSEX's Avatar
Yes you can install aftermarket camber kit with stock suspension.
Old 01-22-2017, 04:05 PM
potmilkz's Avatar
Received 1,020 Likes on 792 Posts
you really dont need front camber kits unless you are going super wide.. even i dont run front ball joints.. just get the rears.
Old 01-23-2017, 09:36 AM
03max6spd's Avatar
Sub'd i have BC coilovers, didnt install yet. How low do you have to go before you need a camber kit?
Old 01-23-2017, 10:49 AM
potmilkz's Avatar
depends on how low you want to go.. fender to tire. tucking tire.. slammed af.. etc.
but generally i would get both installed at the same time as they need to remove the rear arms int he back anyways.. if you do them individually then you will just be paying for extra labor isnt needed.
just simply ask them to put these arms on instead of the others. you are just swapping out arms that they are going to take off..
and again you dont need front ball joints
ive been on bags for nearly 2 years and dont even need front ball joints.. alignments are within specs,
Old 01-23-2017, 11:04 AM
03max6spd's Avatar
Since the car is my daily id probably do fender to tire, no tuck no slammed. i want as smooth of a ride as possible.
So camber kits are basically adjustable control arms correct? just want to verify this as my previous car didnt have camber kits ever made.
what would the suspension do if i lowered the car on the stock arms?
Old 03-09-2017, 12:38 PM
omgitsspooky's Avatar
It would throw off your alignment out of spec.
Old 03-09-2017, 01:13 PM
03max6spd's Avatar
Ah gotcha, im looking to do the SPC kit in the rear and skunk 2 up front as ive heard mixed reviews on the ingalls kit
Old 03-09-2017, 02:43 PM
I'm hoping to avoid the camber kit by going for a mild drop.
Old 03-09-2017, 02:57 PM
03max6spd's Avatar
same but with my luck, ill probably end up getting it
Old 03-09-2017, 04:12 PM
potmilkz's Avatar
just remember.. stock camber arms are meant to be only adjusted within OEM SPECS which means very little adjustment... lowering the car causes natural camber which is out of the range of OEM camber kits.. you will need ones that can correct more camber..
Old 03-09-2017, 04:24 PM
Potmilkz I read somewhere that you maxed out on Teins and you didn't need a camber kit. Did I read that wrong?
Old 03-09-2017, 05:14 PM
potmilkz's Avatar
yea i did, i was still within specs according to my alignment. but that was with some non-agressive wheels.
Old 03-10-2017, 10:13 AM
03max6spd's Avatar
So im thinking SPC in the rear and skunk 2 up front for camber
Old 03-10-2017, 11:13 AM
julius071's Avatar
If you need more camber adjustments please contact T-Demand Japan: ????T-DEMAND(????????) I don't know if they make for the TL's yet but it doesn't hurt to ask!
Old 03-23-2017, 04:43 PM
Former Sponsor
ExcelerateRep's Avatar
Hey guys!
As stated, when you lower a car you naturally gain negative camber, which means the OEM adjustments wont cut it if you're trying to get back in spec! Adjusting camber alone directly effects toe, so if you plan on doing more then a 1/2 a degree or so of tilting or so I'd recommend the toe arms as well.
The setback arm is the least necessary piece out of the three arm kit. The only time a setback arm would really be necessary was if you didn't like the forward position of the wheel in the wheel that occurs when lowering a car. These arms essentially let you move the wheel forward and back.
We have SPC products on our site ready to ship, and if you have any questions or need help getting setup feel free to PM me! Here's what I'd recommend for most:
Front:
Ball Joint: 67135 - SPC Ball Joints - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Rear:
Camber correction arms: 67545 - SPC Control Arm - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Toe correction arms: 67545 - SPC Control Arm - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Happy modding!
Mustafa Muhammad (12-21-2019)
Old 03-24-2017, 06:45 AM
Originally Posted by ExcelerateRep
Hey guys!
Front:
Rear:
Happy modding!
Are you suggesting to buy 2 arms (camber and toe) instead of the 3 arm kit?
Old 03-24-2017, 08:35 AM
Former Sponsor
Every setup is different, but for the most part the set back arm isn't something you'd need unless you:
  1. didn't like the forward position the wheel gains when lowering the car
  2. after adjustments you ended up with something that looked like this:
I hope that clears things up a bit!
Old 04-18-2017, 02:43 PM
5th Gear
509rider's Avatar
Hey guys!
Front:
Rear:
Happy modding!
Are these priced as pairs or individual?
Old 04-19-2017, 01:11 AM
The Original Shawdy
carbonTSEX's Avatar
The ball joints and arms are priced each so you'll need to order a total of 2 each. 1 per side.
Old 04-23-2017, 02:47 AM
Ghettuned's Avatar
No clearance for adjustable A arms
I have a set of adjustable A mounts that don't clear the factory body, i notice there is not much space in there, does spc provide an adjustable front camber that clears factory body/fender? I dont need front to back adjustment but at a 4" drop i am having issues getting clearance in the fender and body with any adjustable A arms, it looks like acura left a tight clearance that no aftermarket adjustable will clear, please tell me im wrong!!
Old 10-11-2018, 06:51 PM
RICHDAKIDD's Avatar
Has anyone bought/installed the 6 piece rear camber set by J-Power & is it any good? It seems to have fairly good reviews. I’m thinking about going with the J-Power due to the huge price difference & savings. J-Power 6 piece set - $180 vs $400 for the SPC brand 6 piece set. All replies, comments & feedback would be highly appreciate it. Thanks, Rich.
Old 11-11-2019, 10:33 PM
8th Gear
Jrsweetspeed's Avatar
Good reading on all the forum posts,
I recently replaced my coilovers with an SPC rear camber kit along with truhart adjustable front camber kit. After lowering, my front camber was out of spec.
After tightening up everything and driving several miles, i'm still getting an occasional knock in the front end.
After tightening every bolt and nut to spec that I touched, still getting the intermittent knock, anyone else experience this?
