Eibach springs and alignment kit
Are you able to lower the TL with an Eibach Prokit and have the proper alignment without a camber kit?
In most cases the front will be within spec, but the rear may need adjustable arms to get within spec. You can do just a camber arm from SPC or their 3 arm kit which is more money but allows full adjustability of toe, camber, and setback (caster).
https://store.excelerateperformance..../i-397295.aspx |
