Brake pads
Brake pads
what brake pads should i get ? Or should i just go to the dealer and buy them from there ?
917-821-6957 HELP THANKS
Autozone.
justnspace (02-06-2017)
If your a baller on a budget and want better than stocks go with Centric Posi Quiet ceramic fronts and rears. That's what I have on mine. Minimal brake dust and has more bite to it.
If you want something cheaper and don't mind worse brakes, rockauto.com has an econonmy section. They also have a stock/comparable section and a performance selection. Always a great place to check.
If you need personalized help and/or rotors and pads, check with vendors excelerate or heeltoeautomotive and they can hook you up!
If you search this forum you shall find the information and opinions you desire many times over, and over, and over.
See my two recent posts....
https://acurazine.com/forums/fourth-...r-cars-955499/
https://acurazine.com/forums/fourth-...e-pads-955511/
I don't mean to be rude, but the quality of the answer depends on the quality of the question.
The correct answer to the OP's question is "it depends".
Seek and you will find.
I'd go with OEM but I'll buy online and not pay retail price. I am at 60K on my original OEM pads and rotors. No problem so there is no point going aftermarket for me.
From the past, I didn't like Nissan/Inifiniti pads so I went with Akenbono ProACT pads and Centric rotors. They worked.
Former Sponsor
Centric Posi Quiets are great pads. The StopTech Street Performance pads are another one worth recommending if you're looking for something with improved performance over the OEM pad.
They offer a stronger initial bite and reduced brake fade in a low dusting/noise pad. You can see them here: StopTech Brake Pads - Street Series - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Good luck!
Good luck!
