anyone running 20X11's?
trying to figure out wheels with rolled and pulled fenders and want to keep natural camber after 1.5-2 inch drop, thanks in advance
The Original Shawdy
Not gonna happen. Maybe with high offsets but you're gonna have to run stretched tires. If you go fender flares then yes you can fit them even with low offsets but it's expensive. $4k+ easily.
cb169 (04-12-2017)
appreciate the input, had my eyes on a set off wheels, your wheels look great btw, these cars seem hard to find some decent wheels because of the high offset factory set up, been searching for weeks and cant find a decent set off wheels although I did come across some 19's 10.5 22 offset for the rears which still seems challenging
The Original Shawdy
Pearson4G (04-18-2017)
The following 3 users liked this post by herbert6368:
- Heh, that's what I'm running right now. 19x9.5 +20 with 245/40 series tires in the front and 19x10.5 +22 with 255/35 series tires in the rear. Front fenders are rolled and pulled and rears are only rolled.
I did however fit a 265/30 tire on the 10.5s while test fitting the other day, but would need a definite fender pull to run it.
The Original Shawdy
I'm currently running 20x9 -4 on 235/30 with -1.6 degrees of camber up front and 20x10.5 +5 in the rear on 255/30's at -2.8 degrees of camber in the rear.
I have SPC front and rear adjustable ball joints and SPC 3 bar rear kit. Just for an idea.
dam that sounds mean, post some pics
carbonTSEX (04-19-2017)
The Original Shawdy
I do have other wheels I'm trying to fit but I may have to go with metal fender flares. They will be 20x10.5 -9 all around on 245/35/20's.
Lmao sheesh. I've been in love with that setup forever now.
Sounds good. Thanks for the advice.
All about the custom plates. As for the fenders, I only have the rears rolled flat. Haven't pulled any of the fenders. Just running the perfect amount of camber.
The Original Shawdy
Anyone ever ran 19x10.5 +22 up front? Or know if its doable?.................man I have never had such a hard time finding proper fitting wheels for a car SMH
