Another fitment question 20x9
I have a 2012 acura tl AWD. Planning on getting 20x9 42 offset squared with hub 64.1 and running 245/35/20. Will they fit without stretching tires or rolling fenders. No drop. Thanks for the input
The Original Shawdy
Both will work at factory height. +35 offset will have more poke than the +42 offset.
Factory specs are 17x8/18x8/19x8 +55.
The Original Shawdy
If you plan to lower. I would go 20x9 +35 on 245/35/20 and just roll the fenders. You won't have any issues after that. Usually it is just the rears that need to be rolled since the fronts are pre rolled from factory. You can play it safe and go 20x9 +42 but it will be cutting it close. Best to just roll the rears anyway for piece of mind.
There is a few cars in the 4G wheel and tire picture/spec thread at the top of the wheel section on here. Check that out for an idea. First one is post #72.
Marmstrong1023
01-25-2016 08:36 AM
