Aftermarket sway bushings
If the aftermarket bushings are made with rubber, they will have no beneficial advantage over the OEM rubber bushings.
The aftermarket bushings have to be made with hard polyurethane in order to limit the sway bar movements for more handling performance.
Not looking for handling performance. Trying to isolate the cause of a persistent suspension clunking noise that couldn't be fixed in ~5 dealer trips. It seems to happen on a few of the other TLs they had on the lot too, hence why I am trying to avoid OEM.
Changing the links soon (Moog) and figured I'd get bushings at the same time.
