2012 TL rim upgrade
Boring Teacher
2012 TL rim upgrade
I just bought a 2012 BWP TL tech. I HATE the stock wheels on this car! So...I am looking to buy some wheels. I want to try to stay with some Acura rims if possible, but I don't like the wheels that are offered as an upgrade to this car. What other Acura rims will fit this car. I like the MDX A Specs, but I'm finding them with a different bolt pattern. Do they make those with the 5 x 120 bolt pattern? How would I be able to tell if they have the right pattern if I'm buying from ebay? Is it listed on the back of the wheel?
Thanks in advance for your help!
I love Acuras and Acurazine. I just traded my 2006 TSX on this TL, so I'm staying in the Acura family.
I have car ADD
07+ MDX Wheels
05+ RL Wheels
09+ TL Wheels
10+ ZDX Wheels
Personally, i like the Optional 20" ZDX Wheels... I was contemplating buying them for my PM SH-AWD TL... They will run about $1800
you can go with the 4G Optional 19" Diamond Cut Wheels ($1600), or the 19" HPT Wheels ($1100)
Also, the MDX 19" Advanced Wheels are nice ($1100)
05+ RL Wheels
09+ TL Wheels
10+ ZDX Wheels
6G TLX-S
Which of the above is the lightest in weight ?
I have car ADD
i honestly, dont know for sure... Acura TL 18" A-Specs were about 27.1 lbs if i recall correctly. I know the ZDX wheels will be the heaviest for sure.
My "guess" would be the HPT wheels 19" wheels..
if its lightweight you want, best not go for OEM.... A pair of Enkei SP03s are nice (had them on my 08 TL-S)... 19" wheels, around 20lbs a shot, good looking, and strong... and fairly priced ($350~ a Wheel)
Received 6,470 Likes
^^^^ The rotors look nice.
Boring Teacher
I don't know if I'm allowed to post ebay auctions, but I was wondering if either of these would work? Can I get some help?
http://www.ebay.com/itm/300378802270...84.m1423.l2649
or
http://www.ebay.com/itm/350192667955...S:1123&vxp=mtr
The sellers are being no help to me in answering my questions.
or
Thank you, but stupidly it's the only mod I cheaped out on; was 320 for rotors & pads. They perform VERY well, especially compared to OEM but the rears were shipped without proper coating, after about 1/2 a year use the black paint has already begun to fade and they're not exactly quiet. Ahh and how can I forget... On a bear mountain run this past fall I managed to get them hot enough to smoke for over 10 minutes although it was quite cold out; I'm pretty sure that resurfaced all four lol..
Anyway, I just saw a WDP (FWD) 4G with chrome 20" ZDX wheels, lowered in NYC They looked good (not my taste though as I don't like chrome rims) and MASSIVE; I wanted to take a picture but the driver was leaving as I was walking by.
Depends on the wheel width. IIRC the stock size/offset is 8" wide and +50 - so +55 should work, but would look even more tucked than the stock wheels. I'm not sure if you would have issue with break clearance - so would be something to check.
I have car ADD
or
or
both will work... dont waste your money of the 18" RL A-Specs... not worth it... the ZDX A-Specs (technically, those are MDX A-Specs) will fit, but that style is kind of played out
Check these out
http://www.ebay.com/itm/ACURA-TL-201...item4cfca76a22
http://www.ebay.com/itm/ACURA-MDX-19...item27c1b8fc9f
^ the 2nd set, was what i originally wanted to put on my PM TL.... they are a nice gunmetal.. i just never went through with it... maybe in the spring time
I have a new 2012 SH AWD. Having H&R springs installed next week. I'm also looking to upgrade to 19" wheels with two goals in mind: Sub 25lb per wheel, with a minimum 9" width. I want to avoid any "fit" issues, not interested in rolling fenders, etc. I'm assuming a 9x19 will work?
Sgt128 (02-01-2012)
^There are lighter, better aftermarket options.
That sounds interesting. I have a 2012 TL SH-AWD w/Tech 6MT on order and should be in by the end of May. It'll have the 18" OEM wheel & tires. This could be an interesting trade. Whats the mileage on 19's?
6G TLX-S
What's the make and model of your winter tire ?
If we subtract the winter tire weight from the 53lbs, then what's left will be the weight of the 18" OEM wheel.
i put on new wheels and tires and notice that 2 wheels has buffs , not scratches but maybe some marks from packaging , what can i use to take them off . Used wheel wax but nothing happened.
